Info assist from anyone that has pulled a C3 steering column
Old 09-06-2010, 04:05 PM
mar
mar's Avatar
Default Info assist from anyone that has pulled a C3 steering column
I want to swap my 74' straight column for a tilt/tele unit. I have the new column and am in the middle of removing the old column and can't figure out how it is going to pull thru the firewall with that 'bracket-thing' sticking out of it. It's the little flat bracket with the wire attached to it sort of under the dip stick tube in the photo. I have loosened the rag joint nuts and bolts and the two nuts on the other side of the firewall, but have not removed them yet. Seems pretty straight forward until this point. Any advice???
Old 09-06-2010, 04:16 PM
...Roger...
...Roger...'s Avatar
The cable bracket with the 2 bolts comes off.
Old 09-06-2010, 04:17 PM
1971corvette
1971corvette's Avatar
I am glad you brought this up as I will be changing one out sometime soon also.
Did you buy a rebuilt one ready to go in ?
c69vete
c69vete's Avatar
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
IIRC, there are two nuts on the firewall holding that bracket on. One is a carrage bolt and one is a stud welded to the bracket. Once they are removed, you will be able to remove the bracket and the column will come out.
Also, when you go to hook up the wiring harness to the column, the position from the standard column to the TT will flip flop. You will figure it out I'm sure.
Old 09-06-2010, 04:19 PM
1971corvette
Not that one Roger' the shift interlock that is on the lower steering tube
Old 09-06-2010, 04:27 PM
mar
mar's Avatar
Can I leave the pinch bolt on the splined end of the shaft and pull the big rag joint connector thru the firewall hole?
BTW: I sourced a rebuilt unit already painted black. I'll post a photo of it later.
Old 09-06-2010, 04:31 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
The bracket that Roger indicates is the one that needs to come off. Two nuts on the interior side of the firewall to remove. You're then left with an opening in the firewall that the end of the column can pass through.
Regards,
Alan
Look at the shape of the cut-out below the circle for the m/c .
Old 09-06-2010, 04:38 PM
...Roger...
Yes
Old 09-06-2010, 04:39 PM
1971corvette
Thanks Alan clears it up for me also.
Sorry Roger didnt think you were looking at the right bracket,my mistake
Old 09-06-2010, 04:49 PM
...Roger...
No problem , I went back and turned my laptop upside down and looked at the pic.
Old 09-06-2010, 05:25 PM
mrvette
mrvette's Avatar
That's because you used to looking from bottom side up, instead of top side down.....
Old 09-06-2010, 06:00 PM
mar
mar's Avatar
Ooooops - I shoulda' indicated orientation in my initial posting. Now I gotta wait until my wife gets back to hep me. She can hold up on the steering wheel while I finagle it from the engine side
Old 09-06-2010, 07:49 PM
mar
mar's Avatar
Roger - the cable bracket does not come off. I took the two nuts off from the cockpit side, removed the two big bolts holding the steering column in the cockpit and have removed the rag joint bolts entirely. The 'bracket' is preventing the column from being pulled into the cockpit. That little arm that has the wire attached to it is hitting on the cable bracket. I am at a loss now?!! (New photo attached.)
Unless...the two nuts I took off from the bracket section are actually 'bolts' that pass thru the bracket....
Suggestions???
Old 09-06-2010, 07:56 PM
...Roger...
Turn the key to on, cut that piece of wire off, push the lever down ,,,,or up,, (I'm getting nauseous looking at this pic upside down),then pull the bracket out and off which will expose the hole as in Alans pic.
Old 09-06-2010, 07:57 PM
Allen_396
Allen_396's Avatar
Rotate the little reverse link arm down that is on the steering column. It is blocking the removal of the bolt that holds the bracket to the firewall. Once that bolt is out, then you should be able to maneuver the bracket out of the way.
The other side of the bracket has that pressed in stud.
Old 09-06-2010, 08:16 PM
mar
mar's Avatar
It had to be simple! My two repair manuals said nothing about 'key to "on"...' part. Thanks! we'll try it again after dinner...
Old 09-06-2010, 09:26 PM
mar
mar's Avatar
Default Ok - column out...time to rest
Got it out - what a pain. But now that I know how to get it out...hopefully I can get the new one in as well or better. The new column still needs a few items where the wheel mounts to the column, but I can inventory what it needs later. Thanks to everyone for all the help!!!
In the second photo I noticed that my new column does not have the spring in the bitter end of the column area. Is that a bad thing???
BTW: I'm guessing that the piece of wire I cut off was somehow related to the horn ground. Any thoughts on that?
Now the real hassle looks like getting the drivers side dash pad unhooked!
To Info assist from anyone that has pulled a C3 steering column
Old 09-06-2010, 09:39 PM
...Roger...
The horn grounds through the column shaft, over the rag joint ,then the steering gear.
Did the ignition switch on the new column come with it or did you transfer it from the old one ? ( they are diff )
Old 09-06-2010, 09:48 PM
mar
mar's Avatar
It came with a new one, but the edge of the chrome lock piece broke of in shipping and the key was actually bent, but did not break off. I was going to take both a locksmith and have him transfer my old key set into the new column. Is that possible???
Also the very bitter end (last 5 or 6 inches) of the new column with the rag joint connector on it is about 1/2" longer than the old one. I was told by a guy selling columns at Carlisle the new column must be adjusted with a slide hammer to make it the same length as the old one. What a terrific piece of information. Is that true???
Old 09-06-2010, 09:54 PM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Only the standard steering column has a spring at the lower end. The T&T column does not have a spring. Sorry I didn't check in sooner. A lot of your problem areas are covered in my Disassembly & Repair papers.
http://jimshea.corvettefaq.com/wp-co...ev09ja2010.pdf
http://jimshea.corvettefaq.com/wp-co...ev13my2010.pdf
Jim
Quick Reply: Info assist from anyone that has pulled a C3 steering column
