upper rad hose keeps collapsing
Old Sep 12, 2010 | 08:33 PM
76cvstingray's Avatar
76cvstingray
6th Gear
Default upper rad hose keeps collapsing
any ideas
i replaced the t-stat thats it
Old Sep 12, 2010 | 08:39 PM
'75's Avatar
'75
With the engine running or after you shut it off?
Old Sep 12, 2010 | 08:42 PM
76cvstingray
6th Gear
after its off
Old Sep 12, 2010 | 08:49 PM
'75's Avatar
'75
I would suspect the radiator cap. As the coolant cools it shrinks, the radiator cap has a valve in it that allows coolant from the coolant recovery tank to get sucked back into the radiator as it cools. Are the coolant recovery tank and hoses intact?
Old Sep 12, 2010 | 10:31 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Old Sep 13, 2010 | 05:03 AM
76cvstingray
6th Gear
thanks i will pic one up today
Old Sep 13, 2010 | 09:50 AM
08vycpe's Avatar
08vycpe
As mentioned the rad cap is a good start. You may also have air in the system. Park the car on an incline so that the radiator fill is higher than the engine. With the engine cold remove the rad cap and start the car. Look into the opening and let the coolant flow for a bit. Put the cap back on and let the car warm up. Make sure you have sufficient coolant in the return reservour so it can suck coolant back into the radiator as it cools and not air.
I think a 16 lb rad cap would be as high as you should go.
Old Sep 13, 2010 | 07:50 PM
76cvstingray
6th Gear
thank you all for the input the new cap did the trick
i really didnt think it was going to be so easy fix,
i'm just glad its not the radiator
To upper rad hose keeps collapsing
