Trip reset.
Old Sep 12, 2010 | 09:55 PM
ozzyrulesme's Avatar
ozzyrulesme
Default Trip reset.
Doses anyone know how to fix the trip reset. Mine is stuck. Will not reset when pulling on the leveler. thanks 1974..
Old Sep 12, 2010 | 10:09 PM
Peterbuilt's Avatar
Peterbuilt
On mine you push the **** UP and turn, and when its all zeros pull it back down.
I think it used to come down by itself.
Old Sep 13, 2010 | 10:31 AM
oldsarge's Avatar
oldsarge
Pushing not pulling is the answer. If that does not work, sometimes the cable gets kinked and you might have to adjust its position, behind the dash.
Old Sep 13, 2010 | 11:30 AM
Sully1882's Avatar
Sully1882
yep push it up...
Old Sep 13, 2010 | 09:51 PM
ozzyrulesme
Default Hey thanks...
Thanks for the info!!! Went out and pushed and turn and got it to reset. the end piece was not there had to use pliers t to do it but it reset . Now need to take it for a run to see if it will turn. It was stuck before.. You guys are alsome!!!!! love this forum!!!!
Old Sep 18, 2010 | 07:30 PM
ozzyrulesme
took it for a cruz and no luck still stuck at 000 . bad gears or cable???????
To Trip reset.
