header question
Old Sep 12, 2010 | 10:57 PM
kmobrien76's Avatar
kmobrien76
Default header question
I have the base 350 in my '74 auto trans..
notice the second set of pipes here: http://www.ecklers.com/corvette-exha...sion-1974.html those are the ones that bolt up to the manifold currently, see how they go "up"
can they bolt right up to: http://www.summitracing.com/parts/SUM-G9003/?rtype=10
Looks like the headers go "straight" and my stock exhaust goes downward..
Kevin
Old Sep 12, 2010 | 11:54 PM
johnt365's Avatar
johnt365
You have to go to a muffler shop that has an experienced welder who can weld the header collector to your existing pipes.
Old Sep 13, 2010 | 12:18 AM
kmobrien76's Avatar
kmobrien76
Wouldn't that not be so good though if I ever needed to pull the engine??
kevin
Old Sep 13, 2010 | 07:38 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
The collector you weld on to the pipes will bolt to the matching collector on the headers, so you're in good shape.
Old Sep 13, 2010 | 03:13 PM
Kevins77's Avatar
Kevins77
Its no big deal to get the exhaust done at a shop - usually very cheap to have them do the last bit of fab. I would say if you have everything ready, its probably ~$50 worth of work to have the shop cut and weld on the collector.
Just an FYI, just about anything you find for a factory car will be for the factory mount location. Basically it is built to work with the exhaust ram or with shorty headers that fit in place, but not any long tube/equal length kind of setups. Anyone with long tubes has had to either buy a full kit including the headers or had fab work done.
To header question
