What makes a tach turn "backwards"?!
Old Sep 15, 2010 | 02:14 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Default What makes a tach turn "backwards"?!
A friend of mine is restoring a '76, he just installed the dash components and yesterday he started the engine for the 1st time, we were surprised to see the tach is moving backwards! .. at idle it stays at 700 RPM but when we rev the engine it turns the other way towards zero, he put a new board there (from Willcox) and zeroed the tach exactly as recommended, is there a polarity that have to be swapped somewhere???
Old Sep 15, 2010 | 04:03 PM
10caipirinhas's Avatar
10caipirinhas
You sure it is not really idling at 666 RPM ?
Old Sep 15, 2010 | 04:10 PM
SteveG75's Avatar
SteveG75
Sounds like he has the power and ground wires backwards to the motor is spinning backwards. Not sure what that would do to the board though.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Electromagnetic discharge from a nuclear explosion...or a failing tach board. Contact Willcox. They had a problem with some of their boards and they'll set things right with you if it's the board.
Old Sep 15, 2010 | 04:12 PM
mar's Avatar
mar
unplug the tach drive cable ends and swap ends. Oh...wait a minute, no drive cable
Try swaping wires.
Old Sep 15, 2010 | 07:24 PM
tnovot's Avatar
tnovot
Driving in reverse? Sorry, someone was bound to say it sooner or later.
Terry
Old Sep 16, 2010 | 01:50 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hamad-
Who is the customer and when did he buy the board.
There was a small sample of boards that had a bad capacitor on them but they would die out at around 2000 and start drifting back to zero. The issue was the supplier of one of the capacitors, and it was not bleeding off signal which in turn confused the chip. (best way I know to describe it),
If your friend wants to send the entire tach in to us, I'd be happy to put it on the machine and actually attach it to a running car for testing... If the board is a problem you know I'll take care of this n/c plus this allows me to calibrate match the board to the actual tach vs. using the industry standard.
Also.. this is the thread on the defective boards.. Hate to say it but it did happen on a small scale but on any scale it was a nightmare... I have to call it for what it is and it was a mess.....
So.. go take a look at this thread...... This deals with boards purchased before May 01, 2010.
http://forums.corvetteforum.com/c3-g...-question.html
Willcox
Old Sep 18, 2010 | 04:43 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Originally Posted by Willcox Corvette
Hamad-
The running backwards is actually impossible...
Willcox
Thanks Willcox for the reply, actually I bought that board from you last Feb on his behalf. When I tested the car again yesterday, actually its idling at 700 RPM and when ever I rev it (even slightly) it would die and go back to 0 , so its as you described except it wont move up above idle at all, it just dies directly.
If you are sure that its the board, then I would just buy another one, because shipping it back would cost me around 40 to 50 bux. One more option is to fix the board locally by replacing the faulty capacitor.
Old Sep 19, 2010 | 11:17 AM
0Willcox Corvette
Former Vendor
Hamad-
Place the order in so that it will process tomorrow! I'll go in the order later today or early tomorrow and delete the cost of the board and all shipping....
I'm not going to have you repair our mistake and I'm not going to allow you to purchase another board...
It's on me... I'll make sure it ships no charge to you.
Willcox
Old Sep 20, 2010 | 10:34 AM
stpman's Avatar
stpman
Now that's customer service
Old Sep 20, 2010 | 11:31 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Thanks a lot Willcox for the perfect customer support!
order placed.
Old Sep 20, 2010 | 03:46 PM
0Willcox Corvette
Former Vendor
Hamad,
Thank you. I just did the edit... it will ship tomorrow.
Old Sep 20, 2010 | 04:33 PM
Scott Marzahl's Avatar
Scott Marzahl
That same thing happened to me with a new board. One of the pins that are riveted to the board was not making contact with the solder trace, I had to add solder to that area to make it work.
Old Sep 21, 2010 | 02:36 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Yep, that's why I like to shop with Willcox.
Old Oct 30, 2019 | 11:17 PM
spectravette's Avatar
spectravette
2nd Gear
My tach is running backwards! It was trying to work when I first got it running, but shortly after it went to about 5 grand and just hovered around there. The car sat since 2005 so I figure a new board might be in order. I took it apart and cleaned all the connections and tried to zero it but now it sits on zero and goes negative when I rev it up.
Old Oct 30, 2019 | 11:20 PM
lars's Avatar
lars
You might want to start a new thread - this is a 9 year old topic in this thread/post...
To What makes a tach turn "backwards"?!
