like a "stone crush"
1971 coupe 4 speed...something sounds real awful when i step on it?? i thought it was from the rear,so i mounted a cam, (like the video about the bad c-clip here on the forum) gassed turned and braked,but i couldnt see any thing wrong.. mono spring,strutrods,half shalfs seems ok.. oils is ok. no heavy leaks.,but the output shalf(gearbox) is backlash? 0,079 in (2 mm) i can not make black lines at all, then it sounds like sprockets are skipping.. joints are ok.. any idea,someone, kjell
A bad motor mount will allow the fan to hit the shroud.
Both make some really nasty noises with hard acceleration without leaving obvious evidence.
