also having rear spring bolt problems
Old Sep 16, 2010 | 01:36 AM
Wadew's Avatar
Wadew
6th Gear
Default also having rear spring bolt problems
I am doing a complete frame off restoration on a 1971. I bought a suspension package and it came with a new comp rear spring that was wider than my original spring. To rectify this I bought a HD diff cover that accepts the wider spring. However this cover has 7/16" threaded holes and my spring kit came with 1/2" bolts. My old diff cover also had 1/2" holes. I dont have a problem buying the 7/16" bolts, but I am planning on building alot of horsepower into this car and am wondering if the lighter bolts will be a problem. I have already rebuilt my diff and painted it, so doubt if I can send it back. Do I worry too much?
Old Sep 16, 2010 | 06:37 AM
fugawi's Avatar
fugawi
yup, you worry to much.. buy grade 8 bolts, and fuggedaboudit.....
Old Sep 16, 2010 | 05:18 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Agree with fugawi.
FWIW, early C3's came with narrower springs and 1/2" bolts, later ones with wider springs and 7/16" bolts. Kit with wide spring should have come with 7/16" bolts. Since you've already purchased an HD cover, IMHO you've already addressed the biggest problem I've seen with older ones; that of spring bolt bosses breaking off.
Old Sep 16, 2010 | 11:26 PM
Wadew's Avatar
Wadew
6th Gear
Default Thanks
Thank you for the replies. I will continue putting things together.
To also having rear spring bolt problems
