MT ET Street Radials
My best E.T. was 7.62 at 95mph with a best 60' of 1.91.. The MPH tells me I should be down around 7.30's if I could hook better..
Start with around 24 lbs. and work your way down to around 20 lbs. They are made to perform best at these pressures.....remember, these are not wrinkle wall slicks. The compound is actually stickier than ET Street bias slicks. And, using a stiff rather than soft rear spring helps more.....less rear squat, let the tire do its job.
Also burnout procedure - no need to bury the crowd in white smoke.....initially give one "good" burnout to heat and clean, then on consequent runs only a quick one is needed. I use a heated 22 lbs. on mine and 60' @ 1.50 with good track prep and 1.60 in fair conditions.
Another good find was I noticed the #7 spark plug boot wasn't clipped on it was barely hanging on by the boot on the tip of the spark plug.
Crazy and embarrassing how well it runs on 7 cylinders.:o Gkull, I doubt at this point in the game I'll change out the heads, but I appreciate your input. I considered raised port heads, but not spread ports. I guess I didn't want to increase the challenge hunting down headers.
There are a lot of killer cars in this post. I hope with everyones help I can get this thing dialed in. I see Rock Falls Raceway (Wisconsin) has a fun run day this saturday, and a muscle car shootout this sunday. I'm asking around for a trailer. If my clutch holds tomorrow, and I can get a trailer, I'll head out for a few passes. I'll keep everyone posted.
From what I can interpet on the Mickey Thompson Webpage, I'd say between the ET Street, and the ET Street Radial, the ET Street Radial has a softer compound and would give better bite.
http://www.mickeythompsontires.com/tech.php?bulletin=s1
I would say the compounds are about equal. My et streets hook harded, but they have more sidewall and do not have the radial structure perform better in street driving though.
Btw Blwn73 I would be interested to see what your car does on a chassis dyno just to see a good look at what drivetrain loss might actually be.
My exact thoughts. I was very interested in finding out the drivetrain loss since I had the flywheel hp numbers. I know the speed shop TNT Performance made mention of another chassis dyno in the area. I'll have to ask. I don't necessarily need the tune, but it would be nice to do a few pulls, and maybe hit the NOS at low boost and get some numbers.
I'm skipping the gym tonight so I can make a few launches, and or 1/8 mile passes after work. It's about 67 degrees and sunny outside. I'm concerned about the clutch more then any hard parts. We'll see.
Nice! I plan on doing the same two dyno deal when I get my 71 running again. I want to know as close as I can the drivetrain loss.
Tire pressure is set at 33 psi. The first test launch at 3000 rpms produced a lot of wheel spin I looked at but didn't even record any time.
Launches at or above 2500 still blow the tires out from under the car off the line. A 2000 rpm launch worked pretty good.1/8th mile pass 2000 rpm launch (pretty good hook and straight)
Distance, ET, MPH, G's
1/4, 12.41, 98.3, 0
1/8, 8.18, 96.3, .39
330', 5.58, 75.1, .52
60', 2.37, 35.2, .74
30', 1.63, 23.9, .66
15' 1.19, 17.5, .67
0-60 mph 3.96 at 173'
0-30 mph 2.04 at 45'
Peak G's .823 at 44.7mph at 93'
1/4 pass 2500rpm launch (Sideways out of the hole)
1/4, 12.62, 121.3, .25
1/8, 8.53, 96.5, .37
330', 5.92, 74.5, .49
60', 2.63, 32.9, .74
30', 1.83, 21.4, .55
15' 1.34, 15.8, .54
0-60 mph 4.41 at 183'
0-30 mph 2.45 at 52'
Peak G's .801 at 36.5mph at 71'
I can really see where the wheel spin effects the ET's. I'll probably need more power or a gear change to really get my 60' times down.
I'm thinking I'll drop a 5-10 psi on the tire pressure and see if I can launch above 2500 rpms.
I do like the trap speed of 121.3mph, that is promising.
Oh oh, now I'm thinking NOS in 2nd, or swapping my pulleys around on the blower for a little extra get up and go.
Yep, this is fun.
I'll find out tomorrow if I can borrow a coworkers trailer and head to the track this weekend.
Last edited by 73BLWN; Sep 21, 2010 at 08:23 PM. Reason: Computer locked up and sent response early
As for your runs..... You need to run no more then 25 psi in those tires when normal driving, then for playing around you need em around 18 psi.....33 psi is WAY too much and likely killing the contact patch and keeping the tire too stiff. Also, you will need to do a burn out prior to a run. Lastly, try to find a good road with some fresh, white concrete...., or maybe something knurled like a feeder road to a local freeway.....And even with all this, that thing is still gonna spin like crazy... Only chance you are gonna have is to get it on a well prepped strip....and pray the rear end holds together...
And for chrissakes, take some freakin in car video and post it up here damn it.
It sounds like I'm on the right track in terms of dropping the tire pressure. MT's site said to start at 75%-100% of max inflated value (44psi) hense the 33psi starting point. I'll drop them down to 25psi for the next testing session. Eventually I'll do a test at 16psi or so, but first I'd like to know what it runs set up how I get in and drive it everyday.
There are a couple freeway areas that have concrete that I would consider knurled. It's a sunday morning area or late evening spot because of traffic. Traffic is always an issue. Gotta keep it safe for me, and others.
I tried to tape a string to my blackberry and video the run. the angle was all wrong. I'll try to work something out and get a video. My wife won't ride in the car.
so she won't shoot a video. mvette76: Thanks, I googled chassis dyno and found that one last night. I may talk to them about re-ringing my motor, engine dynoing, and then I'd throw it on their chassis dyno. Thanks for the info. It's only $75 for two pulls without tuning. Maybe I'll take a day off and schedule a session. Cool.
Fishndude: I like the sounds of that! My current goal was to see a high 11, so I'm getting close. Thanks for the encouragement.
The weather looks questionable until the end of the week, so it'll be bit before I can do anymore tests.
My current setup has 1 3/4" super comps, with a 3" exhaust to 40 series flowmasters. I'm thinking I may keep the 3" exhaust and run some electric cutouts.
How did you figure out the optimum exhaust for your Z06?
Good luck at the track. I look forward to seeing the numbers....I imagine you will trap 125mph plus....probably more like 128-129mph if it hooks in 1st and you nail the shifts.
