MT ET Street Radials
Old Sep 22, 2010 | 09:38 AM
  #41
rj8806's Avatar
rj8806
Originally Posted by 73BLWN
Any suggestion on where to get the TKO 600. I have had bids though Keisler. They weren't worried about 700hp, but I 've changed my goals a bit adding the NOS and switching heads and roller cams and...Now for the drivetrain....
Try American Powertrain (americanpowertrain.com). We have a modified version of the TKO (TKO Extreme) that handles 950ft/lbs and is still fully syncronized. It also ups the shift capabilities to 7200rpm's whereas the "stock" TKO is limited to 6000rpm's.
Old Sep 22, 2010 | 11:57 AM
  #42
73BLWN's Avatar
73BLWN
ajrothm: Thanks for the advice and encouragement. I agree, I'd exspect this thing to be "soft" on the bottom end. The blower is barely doing anything how it's setup right now (3psi). That's why I'm so surprised at it's low end and driveability. I don't really even see any boost until the top end.
The "chokemasters" (funny) have been on there for over a decade. They were hot in their day. I don't like the resonance at 2200 rpms, but like the way they sound at idle. I'll look into your suggestions.
So far no trailer. I'm waiting on my second option. A friends friend has one stored on his lot. He is supposed to be asking if I can use it. You said it, "nail the shifts". So so important. Another thing that has been bothering me is the tach drive cable. It's so unstable. I have a new cable but it's eratic. I'm thinking I should pull my autometer from my mud truck, and mount it in the Vette. It also has a shift light.
rj8806: I'll look into americanpowertrain.com thanks.
Old Sep 22, 2010 | 11:58 AM
  #43
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
sigforty: I agree, I plan on discussing the primary length size, and collector size with Headers by Ed, and Stahl as I move forward. I may buy them direct from Stahl, or have Headers by Ed build be a custom set. The cost is about the same. My skill at that level of detailed welding, well, not so good. l had a 460 ford in a pig torino many moons ago that couldn't bark the tires. I installed a set of hooker super comps, and smoked the tires sideways down the street. My 500hp 144 blower motor picked up 15hp and 10trq across the whole powerband going from 1 5/8 to 1 3/4 headers. Of course the primary length was different also. Good comment and a good reworld example of proof. Nice.
My current setup has 1 3/4" super comps, with a 3" exhaust to 40 series flowmasters. I'm thinking I may keep the 3" exhaust and run some electric cutouts.
How did you figure out the optimum exhaust for your Z06?
I had Larry Meaux do it. (http://www.maxracesoftware.com/) He has some custom software called pipe max that tells you what everything should be. We ran my current setup through it and was able to figure out my headers and collecters were about perfect. (everyone on LS stuff is pushing the 2 inch primaries over 1.75 these days, and I was considering the upgrade) The software told me good lengths for the pulse to exit and that is where I place my cutouts. So for everyday street use I have the less torque due to a non-optimal exhaust length, but when I beat on it and open the cutouts I gain 50 rwtq in the midrange.
Old Sep 22, 2010 | 12:07 PM
  #44
73BLWN's Avatar
73BLWN
Sigforty: Sweet that's what I was looking for. Thanks.
Old Sep 25, 2010 | 11:05 AM
  #45
73BLWN's Avatar
73BLWN
I didn't get a trailer, I see there is a test and tune coming up on Oct 2nd and 3rd. I may check at a local rental to see if they have something appropriate to haul my vette to the track. I'm trying to install my Afr, boost, and fuel pressure gauges at the moment, and fix my dash lights. They quit working.
ajrothm: Looking at my dyno sheet, I see I'm a liar. I do have some boost showing up at lower rpms. Sorry about that.
We were confuse about the afr, and he figured it out some other way so don't worry about the odd lean numbers.
Heres what I have going on with my guages.
I figured I better get my afr and fuel pressure gauges hooked up if I'm gonna be playing around with NOS more aggressively. Not to mention I thought the shift light and Autometer tach might help out with some consistancy.
Old Sep 25, 2010 | 05:50 PM
  #46
ajrothm's Avatar
ajrothm
I'm suprised that the AFR is that lean (14s up to 5400, then 12.9 at 6000)....but the brake specifics are pretty high in the mid 5s(which I would expect for a big blown application with two carbs...)....thats kind of weird.....But sometimes the wideband O2s on the dynos are not that accurate because the are not using oxygen sensors to measure, they use fuel flow/consumption and calculate the air through the carb hat (turbine)....Though I don't see how they could do that on a blow application.
I would damn sure get the best wideband O2 you can on that think and jet it until your in the 11s from 4000 on....
I was hoping you would get some track numbers...Hopefully soon.
I drove mine to the track 80 miles round trip and raced it, two weekends in a row....I was definitely sweating it though with the stock rear end and drive shaft..... With my new stuff coming in, I won't worry about it....
Old Sep 26, 2010 | 10:06 AM
  #47
73BLWN's Avatar
73BLWN
ajrothm: The AFR was reading as expected for a bit, and then the numbers got weird. The exhaust temps stayed the same, etc. We did put a large MAF sensor thingy on one of the two carbs, and measured 585cfm at the higher boost settings. I converted the carbs so they are boost referenced, that may be why it starts out lean. He was confident we were fat, in the mid 12's, and we jetted it fatter until it didn't make anymore power. It will be interesting to see what my innovate afr shows and what the chassis dyno shows. I already mentioned to my manager at work I'd be taking a half day off to dyno during one of the nicer upcoming days.
The track is 100miles from my house. So....I can't take the risk of breakng at the track. Towing it home 100 miles would hurt the pocket book. I'll have no problem cruising out there after I finish the drivetrain transformation. It'll be simliar to what you are doing right now. I"m gonna sell my little 500hp 144 blown baby motor to fund the upgrade this winter.
I'm installing the innovate afr guage today...with the other gauges.
