Hurst Competition plus installed in 69 (Help)
Old Sep 17, 2010 | 06:32 PM
1969BB's Avatar
1969BB
3rd Gear
Default Hurst Competition plus installed in 69 (Help)
I installed a hurst competition plus shifter while motor was out. Now that motor is back in the shifter hits boot frame when shifting to 2nd and 4th. Can I adjust this? Is this common problem? Did I do something wrong?
Old Sep 17, 2010 | 06:40 PM
Bob Onit's Avatar
Bob Onit
Did you use the upper or lower holes on the transmission end of the rods?
This should help you set your Comp + to the short throw position.
It may also be a matter of simply centering the shifter in neutral.
http://forums.corvetteforum.com/c3-t...post1575237795
Old Sep 17, 2010 | 07:56 PM
1969BB's Avatar
1969BB
3rd Gear
I can't remember which holes I used. I will check tomorrow......thanks
To Hurst Competition plus installed in 69 (Help)
