Hi, sorry I can't help you with the cam (I just started researching cams myself), but I did notice that you have a high rise manifold. I didn't think that there is much more room under a 69' small block hood than there is under a 79' hood... do you know if I could fit a high rise?
Weiand 3000 - no clue what it is, but it's a high-rise dual plane.
Holley Street Avenger - with choke
K&N Drop base (air cleaner)
K&N 3" tall filter
Stock air cleaner lid
I rub the bottom of the hood...it fits, but it's wearing a spot, so I want to go to the L-88 hood and a spacer (if needed) under the carb to get the cold air induction working.
