is it safe to
Old Sep 19, 2010 | 06:29 PM
mj9311's Avatar
mj9311
Default is it safe to
lift an engine using one of those plates that bolt to the intake manifold??
Old Sep 19, 2010 | 06:42 PM
John 65's Avatar
John 65
I am sure lots of guys have but I am not a huge fan. I like 4 grade 8 bolts with nice heavy washers, 1 in each corner of the motor, attached to an equalizer with a nice smooth crank, to balance things out during the lift.
Old Sep 19, 2010 | 07:31 PM
Duke94's Avatar
Duke94
That what I use. Those manifold plates scare me especially if it's a foreign made piece as it is only as strong as the weld.
Gary
Old Sep 19, 2010 | 07:53 PM
jordan89's Avatar
jordan89
Old Sep 19, 2010 | 08:09 PM
7T1vette's Avatar
7T1vette
Yes....IF the plate is sturdy enough not to bend under the load, the bolts are properly torqued, and they do not bottom-out in the bolt holes.
Old Sep 19, 2010 | 08:14 PM
dannyman's Avatar
dannyman
Probably are safe enough; but scare the bejesus out of me!
Much prefer the iron chain and a couple of solid bolts.
Old Sep 19, 2010 | 08:54 PM
snoopykissedlucy's Avatar
snoopykissedlucy
I worry about the guys that bolt the plate to their aluminum manifolds and then lift!
Imagine the entire weght of the block being supported by the little aluminum threads on the intake manifold carb base plate.
Old Sep 19, 2010 | 10:13 PM
dugcyn's Avatar
dugcyn
good question. no experience here using that method (chained 4 bolts with load leveler) when pulling engine and trans from mine. i was not willing to gamble body work.
maybe if you have alum intake, heads and no tranny, might not be a gamble there? i just dont want to clean up the aftermath. ugh!
Old Sep 19, 2010 | 10:24 PM
wiseman79's Avatar
wiseman79
I've used one for years, guess I'm a daring kind of guy
It does make angling the motor and trans (yes I've pulled both together like this several times), as with a single hooking point you can tilt or angle it to clear the trans tunnel, radiator, etc. The one I have is THICK with several beads of thick welds with small gaps between them, that way if a weld cracks it doesn't split all the way down.
Old Sep 19, 2010 | 11:21 PM
Rebelrob's Avatar
Rebelrob
I thought the same thing. I just used it recently and it worked great. Used the forward most hole and did not have to use the engine hoist leveler.
Old Sep 20, 2010 | 01:08 AM
eastltd's Avatar
eastltd
It worked OK for me.
Old Sep 20, 2010 | 01:56 AM
cv67's Avatar
cv67
St. Jude Donor '05
Motor and trans hooked together no problem.
Old Sep 20, 2010 | 07:22 AM
markdtn's Avatar
markdtn
I wouldn't be worried about the plate, but I would be worried about pulling the threads out of the intake-especially an older aluminum one. Also it would see that angling it would be more difficult. I have always used a chain and a cherry picker or overhead hoist (preferred).
Old Sep 20, 2010 | 08:01 AM
bashcraft's Avatar
bashcraft
Been using them for years. Just yesterday my brother and I installed a 496 with trans in his '71 Camaro.
Old Sep 20, 2010 | 11:26 AM
TWINRAY's Avatar
TWINRAY
While we're at it - what strength size chain is recommended? thanks
Old Sep 20, 2010 | 11:33 AM
wiseman79's Avatar
wiseman79
Sorry I don't know chain lingo, but the metal for the chain that came with my lift is about as thick a pencil.
Old Sep 20, 2010 | 11:41 AM
mj9311's Avatar
mj9311
ive always used the biggest chain that would fit onto the hook on my hoist
To is it safe to
Old Sep 20, 2010 | 11:47 AM
...Roger...'s Avatar
...Roger...
I used one for the first time about a week ago and it worked perfectly. I was installing an engine for a local engine shop and they made the lift plate and had used it many times.
I will admit (being the chicken that i am) I put my corner to corner chain on loosely just in case.
Old Sep 20, 2010 | 11:52 AM
7T1vette's Avatar
7T1vette
5/16" chain is probably strong enough...but 3'8" chain is better and safer, if there is a weak link.
Grade 2 bolts (5/16"-18) have a 'clamp' load rating of 1400 pounds (each) [5600 lbs. for 4 bolts]. 5/16" chain has a 'working' load limit of 1900 pounds; 3/8" chain has a working load of 2650 pounds. So, you can see that there is a large 'safety factor' for using such a lift plate. Again, the plate should be sturdy (1/4" steel or 1/2" aluminum construction) and the bolts should be torqued properly...about 12 ft-lbs. If each bolt takes torque OK, then there is no reason to worry about the manifold threads.
Old Sep 20, 2010 | 12:04 PM
MrGoFaster's Avatar
MrGoFaster
Worked for me & I have REALLY bad luck!
