Oil??
Sep 20, 2010 | 02:31 PM
Oil??
What is the max cam/ spring pressure you could use on the fallowing oils? Flat tappet cams
Witch would be best??
Shell rotella t triple protection
Mobil delvac 1300 super.
Accel sf 10w-40
Accel SAE 30 non detergent sf
rating
Thank you guys
I have read the oil thread but I'm still unsure
Sep 20, 2010 | 03:42 PM
You use whatever spring pressure that the cam manufactureer recommends. The oil isn't factored into that.
Sep 20, 2010 | 04:34 PM
I was wondering what the max is u can have with out having a lobe go flat
Sep 20, 2010 | 04:38 PM
Quote:
Originally Posted by
billla
Considering that none of those oils are on the list, you must be unsure
One was mentioned but no one could agree on witch to use, and considering my app idk If it's worth the extra $$
Sep 20, 2010 | 04:42 PM
St. Jude Donor '14
Read the first post - there's not one but a bunch. If you're running a flat-tappet cam, you need an oil with sufficient ZDDP.
I don't think anyone's going to give you a spring open/closed pressure that is going to be OK with oil that doesn't have that.
Sep 20, 2010 | 06:13 PM
Sep 20, 2010 | 06:39 PM
PuddleJumper
Accel sf 10w-40
rating
Thank you guys
Don't use the Rotella, I have a new roller setup to prove it
Sep 20, 2010 | 06:54 PM
Phil Zell
what oil do you use now?
Sep 21, 2010 | 12:01 AM
PuddleJumper
Why would you ask?
Phil is using a roller cam set up and you are asking about flat tappet cams.
Very different oil requirements.
Sep 21, 2010 | 12:36 AM
glen242
Why would you ask?
out of curiosty i guess..
