Antenna won't go down
Old Sep 20, 2010 | 05:22 PM
MrMootsie's Avatar
MrMootsie
Default Antenna won't go down
Posted this in another forum...no luck.
I did a bunch of research on this via the search function. I discovered that the blue wire on my aftermarket radio was not connected to the yellow wire coming out of the antenna relay. I hooked the yellow wire to the blue wire. When I turned the radio on, I heard the relay click and listened to the new antenna go up. When I turned the radio on, I again hear click, but the antenna stays up.
so...I took a set of leads directly from the battery to the wires on the new antenna to make sure it wasn't the antenna. As directed in another thread, I alternated +/- leads to gray/green/white. The antenna goes up and down correctly.
What would cause the antenna to default in the up position? Orange and black from antenna relay appear to be correctly connected.
thanks.
Old Sep 20, 2010 | 06:02 PM
mj9311's Avatar
mj9311
i bought my 76 off a buddy of mine and he didnt like that the antenna wouldnt go down so he cut it off with a hacksaw
Old Sep 20, 2010 | 06:07 PM
MrMootsie's Avatar
MrMootsie
at this stage of the game, chasing electrons, a hacksaw is sounding good. But, after chaning the heat/ac switch, cigarette lighter and attaching the blue wire to the yellow wire, I'm emotionally invested in the power antenna.
Old Sep 20, 2010 | 06:42 PM
mj9311's Avatar
mj9311
i understand that i just invested in a wire for my mp3 player untill i actually have the energy to work on that... but maybe i will go mess with that now i did but a universal antenna and just plopped it in the hole but i am doing a motor build and i do have some time before i get my block back.... hmmm
Old Sep 20, 2010 | 07:34 PM
MrMootsie's Avatar
MrMootsie
no fun moving the muffler over to yank the old antenna. Less fun working the wiring harness through the grommet behind the speaker...if you want to do it right.
81, btw.
Old Sep 20, 2010 | 08:37 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
what happens if you simply disconnect the blue wire from the yellow?
If it goes down then the blue is keeping it hot.
Old Sep 21, 2010 | 07:29 AM
MrMootsie's Avatar
MrMootsie
nothing was happening. I also didn't hear the relay click.
Old Sep 21, 2010 | 09:06 AM
jdp6000's Avatar
jdp6000
thanks.
I can only go by the factory wiring,
I can't comment on the blue thats aftermarket. Are you sure thats the antenna wire for this radio?
The rest of the wires are all correct. Green, grey, white, go from the relay to the antenna. There should also be a black ground coming out of the relay.
You don't mention if the orange wire is live. It runs from the CTSY CLS 20 amp fuse in the panel to the relay. It is always hot. This is the one that controls the down function. See if the orange is there and always hot.
Some of the newer antennas don't need the factory relay. Or come with there own relay. The relay in the car may not work with this antenna or you may be trying to use it with 2 relays inline, one in the car and one on the antenna....depending on what type of antenna you have. Is it the factory antenna or has it been replaced.
Jim
Old Sep 21, 2010 | 09:27 AM
MrMootsie's Avatar
MrMootsie
Thanks for the reply. It's a replacement antenna from Zip.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
It's unclear to me whether or not it is already equipped with relay. I have the Pioneer wiring diagram for the radio, and it indicates that the blue wire is for antenna power. The orange wire is connected to the radio wire which requires constant hot. It appears to be correctly connected. If it isn't connected correctly, would the yellow wire from the antenna relay cause the relay to click when the radio is turned on/off?
thanks. This is a useful discussion.
Old Sep 21, 2010 | 09:41 AM
jdp6000's Avatar
jdp6000
Are you sure the its the relay clicking. I have never listened to mine. The blue (in your case)activates the relay circuit to up the antenna. Once you cut power off to the blue buy switching the radio off the circuit is powered by the orange to move the antenna down. Instead of turning the radio off next time disconnect the blue and see if the relay clicks, maybe power is still trickling through your blue....it has to be completely dead when the radio is off. With the blue disconnected see if the orange is live.
The grey and white is the up and down power supply. I don't remember which is which. Easy to check. When you turn the radio on power goes from the blue to your relay then through either the grey or white....identify which one. Once you have figured that out with the radio off the orange should be powering the other or those two wires. Its only for the length of time it takes for the antenna to go up or down,
Its something really simple here, think it through,
See if the antenna has another relay....after market somewhere along the line....some of these new ones have it right on the mast shaft....look underneath the quarter panel....see if you see one.
Old Sep 21, 2010 | 09:49 AM
jdp6000's Avatar
jdp6000
Looked at your antenna link. Its seems thats the correct antenna it suggests it uses the factory relay. No external relay is used. So thats good.
What do you mean by the orange is connected to the radio, I know you need power to hold presets but are you running an orange out of the radio to the relay too?
You relay could be fried. It may not be switching over. Replace it its cheap.
Old Sep 21, 2010 | 10:21 AM
MrMootsie's Avatar
MrMootsie
Bubba wired the orange into the radio to hold presets, I believe. The orange from the relay is also wired into the radio hot.
I've not seen a link for just the relay. I'll hunt.
Old Sep 21, 2010 | 11:06 AM
jdp6000's Avatar
jdp6000
I've seem bubba cause these problems before. Instead of trying to figure out what wires to pull and if bubba caused the problem with the orange. Try this. Disconnect the orange at the relay and run a new wire from somewhere to the relay thats always hot. Try the radio. If the antenna works you will need to figure out the bubba nest.
Jim
Old Sep 21, 2010 | 12:22 PM
MrMootsie's Avatar
MrMootsie
any good suggestion?
Old Sep 21, 2010 | 01:08 PM
jdp6000's Avatar
jdp6000
For power? Take it off the lighter. You can run off the battery if you put a 20 amp fuse in line for safety. Or run a wire from the panel.
Old Sep 21, 2010 | 01:11 PM
MrMootsie's Avatar
MrMootsie
good idea. I just replaced that as well, with a spade connector. I still haven't found an antenna relay, without all the harness to go with it.
Old Sep 21, 2010 | 08:03 PM
KapsSA's Avatar
KapsSA
Sounds like Bubba cut the orange power line to the antenna for power to the radio memory and didn't continue it on to the antenna relay.
I BELIEVE with the yellow powered by the radio lead the antenna will go up, but with no constant hot to the antenna it won't go back down.
The relay is located in the jack compartment for your year.
Pull the plug with the yellow and orange connectors noting which connector in the relay goes to the orange. Run a jumper wire direct to the battery + and to the orange contact at the relay. It should go down with the ignition or radio "off'. If so, contact the yellow contact with the jumper and see if it goes up. If not, contact BOTH yellow and orange and see if it goes up.
If so, run a hot lead to the orange terminal, either tapping into the original orange or I'd go to the fuse panel "batt' term. Use an inline fuse.
Old Sep 22, 2010 | 08:33 AM
MrMootsie's Avatar
MrMootsie
I'll tackle that on Saturday morning and let you know. Yanking the seat and carpet panel makes it a couple hour job start to finish. Thanks for the assist.
Old Sep 27, 2010 | 07:45 AM
MrMootsie's Avatar
MrMootsie
didn't work....grrrr... I'm going to order a new harness and relay and replace the whole thing. It's worth the time. Is an 81 relay the same as the 80? It looks the same, but I can't find it on line.
To Antenna won't go down
