2 Front Sway Bar Questions?
Old Sep 22, 2010 | 12:52 PM
Clams Canino's Avatar
Clams Canino
Default 2 Front Sway Bar Questions?
Hi!
1) Does the "bump" in the center of the front sway bar face up or face down?
2) My new bar has poly bushings.
Does the split in the bushing face the front or the rear when installed?
-W
Old Sep 22, 2010 | 01:17 PM
...Roger...'s Avatar
...Roger...
What bump ?
edit- Oh that bump.......without going out and looking I would bet $5 it goes up !
Old Sep 22, 2010 | 04:56 PM
Clams Canino
Can someone please look?
My thought is that going up it would hit the car?
The rear one goes up - to clear the spare carrier - but that the rear.
-W
Old Sep 22, 2010 | 06:20 PM
pauldana's Avatar
pauldana
The front one on mine the dip goes towards the back.... it seems yours is different, I don't think it matters as long as it does not interfere with the radiator or anything else.. my front bar is HUGE...VBP
Rear faces up, if that means anything....
and as far as the poly bushing placement goes...by going out there and looking how they are so tight in the full metal bracket, I don't think that it matters at all....
hope that helped...
Old Sep 22, 2010 | 06:24 PM
...Roger...
I'm pretty sure if you put it wrong the loops at the end the links go through will be at a bad angle.
Old Sep 22, 2010 | 06:45 PM
pauldana's Avatar
pauldana
mine is a pretty flat bar, and thus can be put either way if the bump went up/down, but again, mine does point towards the rear...
Old Sep 22, 2010 | 06:54 PM
...Roger...
I don't have a car here to look at but I do have a couple factory bars , I'll go dig them out and take a look.
Old Sep 22, 2010 | 06:58 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
yes
Old Sep 22, 2010 | 07:05 PM
...Roger...
I think I would have lost my $5. The 2 bars I have go "back" and down very slightly.
Clams I'm sure someone will chime in that can actually look at their car or take a pic but if you hold it up you will see the ends will be at a bad angle if you put it on wrong.
Old Sep 22, 2010 | 07:18 PM
Clams Canino
How does up/down translate to front/rear ?
-W
Old Sep 22, 2010 | 07:20 PM
turtlevette
-W
Have you gone out and played around with it. It should be obvious to someone with even the slightest mechanical aptitude.
Old Sep 22, 2010 | 07:45 PM
pauldana's Avatar
pauldana
-W
on mine, the curve in the bar curves towards the back of the car, it does not curve up or down like yours..... or im not understanding your description ....
Old Sep 22, 2010 | 10:04 PM
my 76 ray's Avatar
my 76 ray
This is from a '74. I hope it helps.
Old Sep 22, 2010 | 11:10 PM
Clams Canino
No I havn't. It's tomorrow mornings task.
-W
Old Sep 23, 2010 | 12:09 AM
mj9311's Avatar
mj9311
it faces up (on my 76 at least)
and the slit faces towards the back (again on my 76)
and also the bowl like indent on the ends where the control arms bolt up faces up so that should solve that problem
hope that helps
Old Sep 23, 2010 | 09:02 AM
Clams Canino
Thanks all - I have the orientation good. Now I have a bushing issue - starting a new thread. (sigh).
Old Sep 23, 2010 | 09:15 AM
...Roger...
Thanks for not telling us this was an aftermarket bar !
Old Sep 23, 2010 | 09:53 AM
Clams Canino
OOPS!
The general shape of it follows the stock bar anyway - making the same answers applicable.
If it makes you feel any better - I now have to wait for the right bushings.
-W
To 2 Front Sway Bar Questions?
