Confirmation on my Carb thinking
Old Sep 24, 2010 | 10:20 AM
wiguy's Avatar
wiguy
Default Confirmation on my Carb thinking
I have a '79 L48, headers and no cat ( for the record done by the PO). I have an off idle lean condition ( rattling out the tail pipe ). I have adjusted the idle mixture screws to the point they no longer make a difference, so I'm looking at changing the primary rods and jets. It has the stock 40 rod and 72 jet. The car runs great at WOT so I think I need to get thinner rods rather than larger jets. I'm looking for some confirmation I'm on the right track. Thanks
Old Sep 24, 2010 | 11:11 AM
lars's Avatar
lars
Whether your thinking is right or not becomes irrelevant, because you can't buy primary rods for that carb from any source. You can richen it up at off-idle by increasing the pump shot or enlarging the IFR.
Lars
Old Sep 24, 2010 | 11:33 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Is the accelerator pump working right? Have you tried disconnecting the EGR valve? I had the same issue with my 78. Luckily I had some junk Q-jets laying around the shop and found one with thinner rods. Changing them fixed the problem.
Old Sep 24, 2010 | 12:38 PM
wiguy's Avatar
wiguy
Just replaced the pump with an ethanol safe one and it's working fine. The EGR is removed, it was causing a vac leak.
Thanks for the input.
To Confirmation on my Carb thinking
