Lifter Noise?
Old Sep 25, 2010 | 01:47 AM
frintz's Avatar
frintz
Default Lifter Noise?
[I]Re: Solid lifters. If rocker to valve stem lash is correct, what could cause noise like excessive rocker to valve stem clearance? i.e. click click click Is happening on one valve only.
Thank you, FRINTZ
Old Sep 25, 2010 | 02:12 AM
Oldguard 7's Avatar
Oldguard 7
I'm assuming you are speaking of the "hot" lash setting. Does the lifter noise sound louder than usual? More pronounced with engine under load? Can you give us more info?
Old Sep 25, 2010 | 07:27 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Re-lash them all, if there is still excessive noise then there are other possibilities, the ones I have personally seen are rocker studs pulling out, poly locks or plain nuts backing off, cam lobe going south, and last but not least I had a set of Comp Cams pushrods wear down at the ends on me, bad set.
One that hasn't happened to me but is a possibility is lack of oil to that rocker and it wears the rocker and pushrod tip at the same time, if there is only one make sure the pushrod oil hole is not clogged and also check the lifter itself, could be worn out
There's more but it early
Good luck
Old Sep 25, 2010 | 12:10 PM
frintz's Avatar
frintz
Yes, lash has been set hot. The noise is very much like that of a hydraulic lifter that needs adjusting. It's audible at idle as well as during rpm increases.
Old Sep 25, 2010 | 12:27 PM
frintz's Avatar
frintz
Good luck
Thanks much for the possibilities. The noise starts when the engine is started after hot lash adjustment. Wouldn't that eliminate the adjusting nut since it would have to back off? But then who's to say how quickly a nut can back off. All of the nuts seem to require the same torque. I'll check the pushrod for clogging and check the rocker studs. Could weak or broken valve springs be a cause?
Thanks again,
Old Sep 25, 2010 | 01:57 PM
Oldguard 7's Avatar
Oldguard 7
Motor Head is correct. I too would start resetting the lash. He listed some possible causes and so did you. Start with the simple before tearing apart anything.
Old Sep 25, 2010 | 05:20 PM
MotorHead's Avatar
MotorHead
Thanks again,
Do a visual on the springs, you need good glasses or magnifying glass, ( yeah I know they can be taken off and checked ) a broken or weak spring will cause havoc
Old Sep 25, 2010 | 06:33 PM
brando1118's Avatar
brando1118
Don't want to insult, but could it be an exhaust leak?
Old Sep 25, 2010 | 10:53 PM
MotorHead's Avatar
MotorHead
No insult, many have been fooled by exhaust leak tick, sounds just like a lifter ticking
Old Sep 25, 2010 | 11:16 PM
TimAT's Avatar
TimAT
Look at the rocker pivot ***** too. (if you're using that type rocker). If the pivot in teh rocker arm galls, they can get noisy.
Old Sep 26, 2010 | 05:49 PM
frintz's Avatar
frintz
Default Lifter Noise/Exhaust Leak?
Not insulted at all and thanks for the consideration. I did indeed find a large leak on number 3 cyl exhaust gasket between header and head. I replaced the gasket but the noise remained. I was so wishing that was the source of the noise. Which leads me to believe that the noise is from the no. 3 exhaust valve assy. I will check all the possiblilities that have been suggested, starting with the simplest first.
Thanks still, FRINTZ
Old Sep 26, 2010 | 05:52 PM
frintz's Avatar
frintz
Tim
Thanks for the suggestion. Am using stock rocker arms and *****. Will check for wear. There was a exhaust leak at no 3. Replaced gasket. Thought that was it. Noise remained. Will check no 3 exh valve assy.
Thanks much, FRINTZ
Old Sep 26, 2010 | 05:56 PM
frintz's Avatar
frintz
OG
Thanks for the suggestions. I will check all, starting with simplest first. I did find and exhaust man gasket leak at no 3. Replaced gasket but noise remains. I prayed that was it.
Thanks much, FRINTZ
Old Sep 26, 2010 | 06:04 PM
frintz's Avatar
frintz
MH
I'll do a visual of the springs.
Thanks much, FRINTZ
Old Sep 26, 2010 | 06:43 PM
TimAT's Avatar
TimAT
I forgot to add: If you find a rocker/ball that's blue, that's the one- if the bad one is on an exhaust valve, GM recommends moving a good one from an intake position to the exhaust/ GM says the intakes run a little cooler and makes it better for break in.
Old Sep 26, 2010 | 07:05 PM
midyearvette's Avatar
midyearvette
MH
Thanks much, FRINTZ
after all these checks have been done, worst case scenario is a bad valve stem or guide or wiping lobe,
check the lift at the pushrod with a dial indicator..good luck....
Old Sep 27, 2010 | 08:14 AM
MotorHead's Avatar
MotorHead
If you take any rockers off check the pushrod. The ends could be wearing down, ususally on top where it contacts the rocker cup.
A short story, I put a a brand new 355ci together with brand new parts. Hydraulic cam and I used brand new Comp Cams pushrods, the ones with the little ***** on the end and yes they are hardened.
I was constantly getting ticking noises and constantly adjusting the valves and looking for why I had to do this all the time.
Turns out the little ***** on the ends of the pushrods were wearing down, fast. Finally took a rocker off to inspect them and couldn't believe my eyes because I had it running with cutout valve covers and I could see they were getting plenty of oil. All 16 of them were worn down with low pressure single springs.
I replaced them with CC Magnum pushrods, and the problem went away. I use the same pushrods in my new 427ci with over 400lbs open spring pressure with no problems.
Also what oil are you using ? If not enough ZDDP then you could have a lobe going south.
To Lifter Noise?
Old Sep 27, 2010 | 08:47 AM
frintz's Avatar
frintz
Ahhh, sounds like a possibility. Thanks for the identification info. I'll check it out.
FRINTZ
Old Sep 27, 2010 | 08:51 AM
frintz's Avatar
frintz
Thanks for the suggestion. I hope I find an "easy" answer first.
FRINTZ
Old Sep 27, 2010 | 08:58 AM
frintz's Avatar
frintz
In a week I'll have time to inspect again. Will look at pushrods for wear. Am using Castrol GTX 10-40. Any comments on that oil?
Thanks, FRINTZ
