Question on NOS.
It didnt start out this way, but my car is a Sleeper( :sleep: ) and I would like to try and keep it that way, so what kind of a system would I need? I know nothing about the NOS system so all the help and instructions I can get will be helpful
But the small shot of NOS isn't completely out of whack, but I wouldn't do it myself.. I'd rather do a new cam or different gears, or something along those lines. A halfway decent NOS setup would run you $400-500 anyhow, and you can do those other things for the same or less.
Sleeper? I don't think too many people consider a vette a sleeper...
Daniel
If you have a holley carb... they make a nifty little device for a 75 hp shot... sits right under the aircleaner... Sleeper...
I'm thinking about linking a nitrous system to the kickdown on the trans... :reddevil wonder what kind of tire roasting could happen with that?
dont rat me out for stealing the pictures:p:
Competition Motorsports Nitrous Switch....they havethem for holley, demons, and dominator carbs
Jacobs nitrous mastermind....as danielle77350 said
here is a description from jacobs web site:
The Nitrous Mastermind works by pulsing the nitrous solenoids at the onset of nitrous flow (which is adjustable) and gradually reducing the pulsing until the "full flow" setting is reached. Additionally, the Nitrous Mastermind monitors fuel pressure, engine RPM, and full throttle conditions (using a full throttle switch. Should a drop in fuel pressure occur, the Nitrous Mastermind immediately reacts and shuts off the nitrous flow, thereby protecting the engine from damage. The rev-limiter also protect the engine by shutting down the nitrous first then cutting out the ignition to progressively. This prevents a buildup of nitrous in the engine and exhaust that can cause damage when the ignition "cuts back in."
fuel pressure safety switch.....if you get the nitrous mastermind, it comes with one i believe
safety blow off cap and blow down tube.....
[Modified by 74VETTE, 8:29 PM 3/31/2002]
