Gravity bleed brakes
Old Mar 31, 2002 | 02:12 PM
Roadster71's Avatar
Roadster71
Default Gravity bleed brakes
I used this process on my 71, but for the life of me can't remember how it went. Anyone know? :D
Old Mar 31, 2002 | 08:59 PM
lyonsh's Avatar
lyonsh
Default Re: Gravity bleed brakes (Roadster71)
To gravity bleed, you make sure the master cylinder is full of clean brake fluid, crack the bleeder screw open, and wait until clean fluid comes out of the bleeder.
In my experience, gravity bleeding is great for:
(a) filling a new system or one you've replaced lines in,
(b) bleeding a system that just doesn't want to cooperate with the other methods. Since C3 brakes are notoriously uncooperative, gravity bleeding is a common procedure.
After gravity bleeding, I always do a manual bleed (pump once, crack bleeder, close, repeat as necessary) just to make sure. I've been told it's not necessary, but I don't care - I do it anyway. I want to feel that pedal solidify while I'm sitting still.
Old Mar 31, 2002 | 10:31 PM
Roadster71's Avatar
Roadster71
Default Re: Gravity bleed brakes (lyonsh)
Wasn't there something about the corner your bleeding having to be higher than the others? Thanks for the response
Old Mar 31, 2002 | 10:49 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
go to http://www.motiveproducts.com for a pressure bleeder that will save to time and trouble. :chevy
Old Mar 31, 2002 | 11:11 PM
ComputerGuy's Avatar
ComputerGuy
When you gravity bleed, car is supposed to be even (just like it sits on the tires. I put mine up on stands (even), and gravity bleed and then pump bleed the brakes. Works every time.
Old Apr 1, 2002 | 12:08 AM
Roadster71's Avatar
Roadster71
Default Re: Gravity bleed brakes (ComputerGuy)
Thanks for the responses
Old Apr 1, 2002 | 03:38 AM
Rockn-Roll's Avatar
Rockn-Roll
As I understand it you actually create a leak in the system, then plug it up. I don't want to rain on your parade, but leaks cause air to get into the system...that's why fluid exits the bleeder in drips...cause air is getting in back of it and separating the droplets.
Get a clear hose and a clear bottle, you can buy it already selected for you called a "one man bleeder kit". I also suggest you contact your state's Department of Motor Vehicles and purchase their "Brake Inspection and Repair Handbook" to learn about brakes like I did.
Old Apr 1, 2002 | 08:28 AM
Tom454's Avatar
Tom454
Default Re: Gravity bleed brakes (Rockn-Roll)
Gravity bleeding works fine... I've been using the technique professionally since about 1964 on cars that can be bled that way.
No air will sneaK in behind the exiting brake fluid.
There are several methods for bleeding brakes and they all work fine as long as you do them right.
To Gravity bleed brakes
