4 speed to maybe 5 ??
For me, I wanted the best in all situations, I went with a Richmond overdrive 6 speed. Pretty much a direct replacement for the muncie, works with your mechanical linkage, and you can chose gear ratios to work with your rear end ratio.
I figured that with the torque of our cars a six speed would be not required; alot of shifting when you could "ride" the wave of torque
Now this is based really on nothing. I have driven a '66 vert with a 502 and a 5 speed. I must admit not being overly impressed with the transmission. That was a TKO. I did like the long leggedish of the car however.
With my "new" engine complete I would like to go with a 5 speed, I liked the Classic Chevy kit. Can you give any details why you like the 6 over the 5?
What is the deal with the Richmond 6 speed? Almost a direct swap? If so why don't people use them the Richmond transmissions vs. the TKO.
Carbster
I liked it because of the availability of dozens of different gear ratios. With a newly rebuilt 3.08 rear end, I was worried a 0.64 would be too high of a gear. The Richmond was available with a 0.76 OD.
There are 3 modifications to use it in your vette.
1) Trans mount needs to be moved back and down. I cut mine shorter and made a new rubber mount that was 1/2" lower.
2) Output yoke (th400) might bind on speedo gear, although mine did not. They recomend cutting it shorter.
3) Shifter; it comes with the Long shifter. If you want it to look like the original 4 speed, buy a 67 Hurts t shifter handle. It bolts directly to the Long shifter
Bolts to your bell housing, uses the same clutch linkage, mechanical speedo screws in, shifter in stock location, no drive shaft mods....
Price of a ROD (about $3k) is about the same as a $2k TKO with the $1k mods you need to get it to work in a vette.
Pick your input spline count and gear ratios.
http://www.richmondgear.com/07pdfs/RG21.pdf
fine spline input shaft ?
I have a 3.08 rear gear and TKO 600 .64 OD. The torque of my previous 406ci and my current 427ci small block make cruising on the highway a pleasure, especially when a new car comes up fast behind you thinking you you are a stock C3.
You can also get a higher .87(?) OD gear too
1700 RPM @ 70 mph or 1900 @ 80mph I got 24 mpg on the highway with the 406ci @ 80mph and you put your foot into it and no hiccup or hesitation it takes off.
I am doing a test right now with 427ci, first city mileage then I am going to see what I get on the highway. The 427ci is over 600HP and I bet I get over 20mpg on the highway, I am going to cruise at 70-80mph and I would not be surprised to see the same or better milage than the 406ci
You nearly have me convinced. I will do a little research. No kit sounds good. As I am currently out of the country working until I return I need to have a decent shop do mine! I am still looking for the shop. I "thought" I had a guy, but really anything a little out of the box he really did not want to do and the hour rate which looked "good" merely meant more hours were "needed". I like the idea of the different ratios as well.
Back years ago when I had a '78 Trans AM with built 400 and a 4 speed I lusted after a Richmond OD!
Carbster
If you don't really need the overdrive ratio in the 5/6 speed trannies, just replace the links and bushings on the shifter/tranny. If that doesn't fix it, get the 4-speed rebuilt. Lots less expensive....and it already fits!
