70 wiper motor problems
Old Sep 27, 2010 | 10:59 PM
forman's Avatar
forman
Default 70 wiper motor problems
I still have the motor in the car and i tested it all I am getting is a clicking noise .I put the hot in the center and the ground to the left and right terminals on the one side it clicks but the other side i get nothing is there any way else to check if its good before I take it out thanks
Old Sep 27, 2010 | 11:20 PM
thatcorvetteguy's Avatar
thatcorvetteguy
Go here for the best help with your wiper motor. http://willcoxcorvette.com/repairandinstallhelp.php
Old Sep 28, 2010 | 06:10 AM
forman's Avatar
forman
I already went there thanks
Old Sep 28, 2010 | 07:55 AM
...Roger...'s Avatar
...Roger...
You need to be more clear about how you did your testing.
#1- Ground the case of the motor
#2- Apply 12v to center terminal
#3- Ground right terminal ( blue wire terminal)
.......Motor should run on high
From your description above it sounds as if your missing #1, the motor case ground.
To 70 wiper motor problems
