Have a 74 vert putting steeroids on I have run inot a clearence problem with the fluid line that runs from left of the passenger side mount and under the pan back to the control valve I have a finned pan standard depth if I notch the fins I think I am still going to have a problem with the line not clearing any suggestions would be greatly appreciated
I have s 72 big block with Steeroids. You should be able to bend that hard line enough to clear the pan. If you can't do it on the car, remove the line and get one of those tubing benders so you can make some tighter beds and make it fit in front of the rack. Otherwise, you can contact whoever supplied your unit and ask if they can fabricate a longer line for you.
I was thinking the same thing about re bending toward the front I had to do some re bending on the fuel lins of my 76 last year but those bends were not near as tight as these thanks for the reply
