no spark
Old Sep 26, 2010 | 02:31 PM
markhperry's Avatar
markhperry
Default no spark
69 427/400 changed distributor to pertronix because I could get no spark on TI. I can still get no spark. I have changed 3 ground straps and cleaned motor mount ground and neg ground strap. What can I check now?
Old Sep 26, 2010 | 03:32 PM
JimT's Avatar
JimT
Be sure you have the correct voltage (12 Volts) on the distributor "hot" wire.
Old Sep 26, 2010 | 03:58 PM
TimAT's Avatar
TimAT
The TI quit, and the Pertonix won't work. Did you try another coil? And you did wire the Pertronix so it's bypassing the TI amp and going direct to the coil?
Old Sep 27, 2010 | 09:37 AM
markhperry's Avatar
markhperry
I have 12 volts to coil and i bought a coil to match the pertronex. What do you mean by bypassing the TI amp. Do I need to unplug it? The wire that went to the pickup coil on the TI distributor is disconnected. I have the red wire to the positive side of coil and black to negative and 12 volts to coil but still no spark..
Old Sep 27, 2010 | 11:07 AM
7T1vette's Avatar
7T1vette
I don't know that the TI distributor and the Pertronix system are compatible. The TI distributor is a "magnetic pulse" system, not a 'points' system. It might be able to feed a signal to the Pertronix, but I would call Pertronix and ask them, just to be sure. The Pertronix was developed to replace a 'points' ignition system...they may never have considered that someone would try to convert a TI system with it.
Old Sep 27, 2010 | 01:38 PM
markhperry's Avatar
markhperry
I have replaced the TI distributor with a points distributor and put the pertronix in it. Why no spark ?
Old Sep 27, 2010 | 05:58 PM
myk7's Avatar
myk7
Have you checked for 12 volts at the coil while it's cranking?
Old Sep 27, 2010 | 07:34 PM
7T1vette's Avatar
7T1vette
Bad condenser? Welded points? Broken [internally] wire in the system? Bad distributor cap? Bad rotor? {lots of possibilities}
Old Sep 27, 2010 | 07:36 PM
Roughrider's Avatar
Roughrider
Try a different coil...the TI coil is specific to the TI distributor. It may not be compatible or at fault to begin with.
Old Sep 27, 2010 | 07:53 PM
markhperry's Avatar
markhperry
bought new coil to match pertronix. Have 12 volts at start have not check for 12 volts while cranking
Old Sep 27, 2010 | 09:37 PM
68blueshark's Avatar
68blueshark
Hello
The wiring diagram is pretty simple- positive from battery to starter- starter to ignition switch- ignition switch to positive coil side- (resister) wire from starter to positive coil side-
Also, the distributor housing has to be grounded to the engine block - usually the hold down bracket holds the distributor as it is bolted into the top of the engine block- check for a good connection on the hold down bracket on the distributor and engine block.
You may have a bad ignition switch.
The coil is good if there is .6 to 1.5 ohms on the primary circuit ( positive to negative on the coil) and 8,ooo to 12,000 ohms on the secondary side (positive to center wire on the coil) of the coil.
Pertronix also recommends to increase the spark plug gap by at leat .005" from the factory .035" gap. I set my plugs to .040" and the car ( 68 327- 300 hp) does run better.
Good luck.
Old Sep 27, 2010 | 09:52 PM
markhperry's Avatar
markhperry
How can you tell if you have a bad ignition switch?
Old Sep 27, 2010 | 11:31 PM
thatcorvetteguy's Avatar
thatcorvetteguy
If you had a TI you'll want to use the white wire coming through the fire wall just to the left of the dizzy. It is 12 V's off of the ign switch. There is no res. wire on the white wire it's a full 12 V's. If you need a drop down in voltage split the main harness that goes to the right side of the car on the fire wall behind the dizzy and you'll find a caped wire the went to the point type dizzy. It will have about 9 volts.
Old Sep 28, 2010 | 09:57 AM
7T1vette's Avatar
7T1vette
Has the car actually run on the [converted] points system yet? If not, since it was on TI system, your plugs may be gapped too large for the standard coil system. Plugs with TI get gapped to .045; plugs for points get gapped to .035...because of the lower coil potential voltage.
Old Sep 28, 2010 | 11:02 AM
mlibhart's Avatar
mlibhart
Is the small black ground wire inside the distributor still properly connected?
Old Sep 28, 2010 | 01:04 PM
markhperry's Avatar
markhperry
The car has not run since I have no spark. If the gap in the plugs are wrong, it would still fire.. Correct. The ground wire in distributor is ok I have checked it.. It is grounded.
Old Sep 28, 2010 | 02:28 PM
Roughrider's Avatar
Roughrider
Try disconnecting the coil wire from the distributor and ground it near the engine block...does a a spark jump from the wire to the block? If so, your problem is in the distributor. If no spark, the problem is before the distributor, such as the coil or wiring to it.
You can also disconnect the spark plug wires one at a time hold it near the plug end and see if each has a spark jumping to the plug. Don't hold that by hand...get a tool made for it or you'll never forget the shock you get.
Several years back I had a problem where the engine would turn over and not fire. In my case the coil wire had a pin hole worn through the wire's jacket and the spark was escaping and grounding out against the metal shroud around the distributor. Replacing the coil wire fixed the problem.
Old Sep 28, 2010 | 10:59 PM
thatcorvetteguy
Yes it would still run.
To no spark
