Wheel Studs
Old Sep 19, 2010 | 01:42 PM
jordan89's Avatar
jordan89
Default Wheel Studs
I'm looking to replace all wheel studs on my '74 and need help figuring out which ones I need. I'm looking at the ARP wheels studs and on the Jegs catalog I see that ARP(100-7713) are listed for f-bodies and Corvettes. So will these wheel studs fit both front and rear?
Here's the link:
http://www.summitracing.com/parts/ARP-100-7713/
Old Sep 19, 2010 | 02:06 PM
wcsinx's Avatar
wcsinx
Here's the link:
Those are metric.
Old Sep 19, 2010 | 02:11 PM
jordan89's Avatar
jordan89
:oGuess I should have looked closer. Anybody know if ARP has some for these older Vettes? Part# or something?
Old Sep 19, 2010 | 02:28 PM
wcsinx's Avatar
wcsinx
I would think so. They're 7/16" 20 TPI press in studs which is a configuration used on shmillions of cars. Other than that, you need to match up the knurling and length.
Old Sep 19, 2010 | 07:50 PM
jordan89's Avatar
jordan89
I'm going to see if I can find something that works. Thank you for your help.
Old Sep 20, 2010 | 12:00 PM
GS977's Avatar
GS977
i just posted the same question for my 82
if your 74 uses the same studs an 82 does then it's 7/16-20- .480 knurl.
i believe the ARP is .486 knurl and will work.
i think these will work for you. ARP 100-7701
Old Sep 20, 2010 | 03:15 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
the 7701's will work
Old Sep 20, 2010 | 06:17 PM
Ironcross's Avatar
Ironcross
Go to your local parts store and have them look up the studs in 'Dorman products....they should carry the regular stud and those in a long stud if needed......
Old Sep 21, 2010 | 10:39 AM
Big Block 69's Avatar
Big Block 69
I got these from NAPA. I think they are 1/4 in. longer than stock.
5#641-1268 7/16-2 x 2-1/8
Old Sep 23, 2010 | 10:26 PM
jordan89's Avatar
jordan89
So these will fit my '74?
http://www.summitracing.com/parts/ARP-100-7701/
Not a bad price for a set of 5.
Old Sep 24, 2010 | 12:01 PM
jordan89's Avatar
jordan89
ttt
Old Sep 24, 2010 | 12:12 PM
GS977's Avatar
GS977
yep, thats the ones. i just got 4 packs of them from summit.
Old Sep 24, 2010 | 03:03 PM
jordan89's Avatar
jordan89
Looks like I'll be placing an order pretty soon. Have you installed them? Let me know how it goes. Oh, post pics up too.
Old Sep 24, 2010 | 03:13 PM
GS977's Avatar
GS977
no, it will be a couple of weeks before i have a chance to install them
Old Sep 24, 2010 | 03:17 PM
jordan89's Avatar
jordan89
Do they look like they'll fit? I just want to make sure.
Old Sep 27, 2010 | 01:20 PM
jordan89's Avatar
jordan89
OK, so I went over to my local parts store and bought two sets of ARP 7701 wheel studs. These thing are beefy, and long. Will these also work for the front since they're long?
Old Sep 27, 2010 | 01:22 PM
MrJlr's Avatar
MrJlr
Do you have to disassemble the trailing arm to do the backs ?
To Wheel Studs
Old Sep 27, 2010 | 01:28 PM
jordan89's Avatar
jordan89
I'd say so since these are longer.
Old Sep 27, 2010 | 01:30 PM
MrJlr's Avatar
MrJlr
I wont be doing THAT anytime soon
Old Sep 27, 2010 | 09:44 PM
jordan89's Avatar
jordan89
ttt
