Hum in front while turning
Old Sep 30, 2010 | 06:34 PM
marting163's Avatar
marting163
Default Hum in front while turning
71 vert has hum in the front end while turning both directions but no noise when parked and you turn the wheel? Sounds line a pump of some kind but no noise when parked seems odd what else to check?
Old Sep 30, 2010 | 07:35 PM
wombvette's Avatar
wombvette
Power steering pump probably needs fluid, but you should hear the noise sitting still and turning with the engine on.
Old Sep 30, 2010 | 08:14 PM
marting163's Avatar
marting163
It doesn't make the noise if parked and engine on when turning just when turn and moving like a hum wa Hum wa maybe another pump trying to work?
Old Oct 1, 2010 | 01:28 PM
marting163's Avatar
marting163
Driving today when cold noise is gone, so happens only hot and after been at road speeds , could this mean I need chassis grease or what else?
Old Oct 1, 2010 | 02:41 PM
blckslvr79's Avatar
blckslvr79
Very strange.
Old Oct 1, 2010 | 04:39 PM
marting163's Avatar
marting163
What could tires rub hot they don't rub cold , tires seem to be clear of all rubbing?
Old Oct 1, 2010 | 08:05 PM
marting163's Avatar
marting163
What could expand when hot that the tires could hit! Not a hot or cold tire causing the trouble.
Old Oct 1, 2010 | 08:18 PM
Bowerss2's Avatar
Bowerss2
must have forgot the words.
Old Oct 1, 2010 | 08:32 PM
Timsride's Avatar
Timsride
Its probably Your power steering as it builds pressure to turn tires.
Old Oct 2, 2010 | 07:41 AM
marting163's Avatar
marting163
So does the pump need replaced if I'm going to do long drives , it does sound like a pressure build thing?
Old Oct 2, 2010 | 10:34 PM
my 76 ray's Avatar
my 76 ray
How fast are you going and how hard are you turning when it makes the noise? Are we talking about taking a 90 degree turn at an intersection while doing 10-15 mph or doing a hard curve on a back road at 35-40 mph or a slight curve on an interstate at 60-70 mph?
Old Oct 3, 2010 | 10:03 AM
marting163's Avatar
marting163
This is at low speed turns, stopped then turning at intersections or 10-15 mile turns or pulling in the driveway at the end of a cruise.
Old Oct 3, 2010 | 12:37 PM
noonie's Avatar
noonie
Try taking the reservoir off the pump, cleaning it well and also the flow/relief valve.
These pumps valves can get pretty crudded up inside since few ever change the fluid. At the same time flush the lines etc.
Repair kit for the pump is pretty cheap.
Old Oct 5, 2010 | 01:39 AM
my 76 ray's Avatar
my 76 ray
It doesn't sound like power steering to me. There is more resistance when sitting still than moving, so I would expect it to make noise even sitting still if it's the power steering system. Have someone stand outside the car and listen while you make a turn. It could even be coming from the rear of the car. Sometimes it's hard to tell from inside.
I'm thinking it could be a wheel bearing, maybe even a u-joint or differential yoke if it's coming from the rear of the car. In any case, I would look at parts that only move when the car is in motion. It's also possible that it's making the noise at higher speeds but you just can't hear it due to road noise.
To Hum in front while turning
