Dose anyone have a schematic for the horn circuit for a 78. someone attacked mine with a pair of wire cutters. I would like to make it like it originally was. it would be greatly appreciated. :eek: Thanks in advance
This is what I know about the horn circuit
When you push the horn it grounds a relay that alows power to go to the horn and the horn is case grounded.
It's that simple. :cheers:
Thanks aron but what i really need to know is the wireing under the hood .The preavious owner hacked it up and there looks like there is something missing next to the altinator. like a relay (2 holes in the fender well and some cut wires) but i know there is a relay under the dash for the horn. Thanks for any info :cheers:
The wires that supply power to the horn should be green and run down the Drivers side engine compartment just under the fender lip.
I hope this helps :cheers:
