BigBlock or Small Block?
Old Apr 1, 2002 | 08:37 AM
FinnShark's Avatar
FinnShark
Default BigBlock or Small Block?
There is no answer for which one is better, but I'd like to know the good sides and the bad sides about these engines...
Ofcourse BB has more power and torque, but it is also heavier and makes the weight balance of the car little bit weird... Spare parts are more expensive to BB (I suppose?), but on the other hand BB is more respected...
I'm just trying to get a some kind of a sence wether to buy a BB or SB.
Old Apr 1, 2002 | 08:45 AM
73-454's Avatar
73-454
Default Re: BigBlock or Small Block? (FinnShark)
In one of the Vette Mags the tech guy said it is very expensive to install a BB in aSMB vette if done properly. Next question how big is your budget. The engine alone will cost you 2 to 3 time more the a 350. You are right BB are more respected then the small little brothers.
Old Apr 1, 2002 | 10:38 AM
454Big's Avatar
454Big
FinnShark, view my sig!!!! :D
Old Apr 1, 2002 | 11:13 AM
groovyjay's Avatar
groovyjay
Hi Riku, sorry we didn't get to meet each other at the show last weekend. I went there on friday and just had a quick run through.
Ok, back to the original question, as you may know my car used to be a small block when I first bought it and it was sporting about 300bhp and same amount of tq. After some time this just started to feel like not-enough and I started looking for the different alternatives wheter to try to squeze more power out of the mice block or go for the rat block. After having had test drive in 454 Chevelle there was no going back.
I found brand new LS-6 specs BB and just dropped it in and I was pretty satisfied with the result :D the endless torque is something you don't get with stock small block. My engine was all stock with iron heads and after spend few laps on alastaro and ahvenisto it came clear to me that the car wasn't handling too good and something had to be done, it went on a DIET!!! :lol:
As you know my car is still under body off restoration and what I've done to improve the handling is a lot! I went from VB&P slalom suspension for Performance + kit which includes tubular a-arms and composite mono spring on front and composite mono spring on rear. Then I added offset trailing arms and changed all bushings to poly. I also installed steeroids rack & pinion kit. New wheels came from American racing and are TT IIs in 20" diameter.
As for the engine I tried to use as much aluminum as possible and here's what I've got now: Edelbrock aluminum oval port heads, edelbrock EFI w/ aluminum intake, Edelbrock aluminum water pump, BeCool aluminum radiator, aluminum radiator frame and most of the body/bumber brackets are currently been made out of aluminum. All the canisters will be polished aluminum too. I just ordered complete serpentine conversion with aluminum pulleys and brackets from March Perf along with small late model style steering pump.
After this project is completed it is time to see the difference and I trully hope it is going to be huge.
Oh, your orinal question... maybe I was just trying to give an idea what needs to be done if you want to make your big block car to handle like late model vette. I think that all iron BB is not a good choice when you're looking for good handling car. Yes, it will be a fun drive and it will drink all that petrol you'll poor in the gas tank, so in the end it'll be your choice.
Just my 2 cents.
PS:How was that '80 that you went to take a look in Vantaa? :cheers:
Old Apr 1, 2002 | 11:19 AM
GWHITE75's Avatar
GWHITE75
I went from a SB to a BB and I can say I don't regret it. I have had SB motors for years and still like them, but I could not pass up the opportunity to rebuild my car and put a big block in it. With a BB, it's easier to get good, streetable HP and TQ. The initial cost for pulleys and brackets was about $300 for all new. I put aluminum heads on it, so the weight difference was reduced significantly.
As for parts costs, the increase in parts prices is not significant and, again, you can get good streetable HP and TQ with less radical parts than what you might have to put in a SB to achieve the same specs on power. I do miss the revs of the small block a little.
Old Apr 1, 2002 | 12:36 PM
verskel's Avatar
verskel
My "vote" is for a Big Block !!!
Big block disadvantage include 'running hot' (overheating) - if your in cooler climates this is less of a worry & elec. fans usually solve this problem. :)
Small blocks usually get better gas mileage but often lack the 'streetable' power that everyone expects from a vette. :chevy
To BigBlock or Small Block?
