How to trouble shoot 74 starter/electrical
Here is what I have done:
1. Checked battery, all good connections, have power-lights and horn working
2. Checked battery cables, ground wire to frame is good
3. Re-installed old alternator to rule out bad connections or bad alternator
4. Jumped starter on two terminals had power
5. Took off the starter and had it tested, tested good, re-installed
6. Located the clutch safety switch and jumped the two purple wires on the connector, nothing
7. Have new MSD coil, so should be fine there
8. Down to testing the ignition switch I guess
What I need to know is how do I go about testing the ignition circuit for power. I am going out to get a circuit tester. Any ideas?
There is a ground wire that lots of people accidentally put on the big solenoid 12v. I don't think that keeps it from starting though, just keeps the wipers from working right.
Make yourself a 12v test light with a brake light bulb and some alligator clips. clip it on the purple wire on the S terminal and ground and hit the key, The light should come bright every time.
If it does not, then start working backwards through the start circuit. If it does, but still no start you have a starter problem, keep looking. Be sure the engine ground under the right side motor mount is good, it mave gotten cooked by the new headers
...1974s and early '75 Corvettes had a seatbelt/by-pass/interlock module relay up on the passenger side firewall above the heater core cover and has an orange plastic base with a silver cadmium relay cover with a black rubber/plastic by-pass button. This went bad on my '74 about 4yrs ago and took me more than a few hours to also figure out why my starter wouldn't crank my '74. I had to by-pass it internally under that relay cover that comes off by gently prying and opening up a few bendable tabs. Been perfect ever since.
Also tried to see if I had power to the coil. Attached to power side and grounded and light came on, but when I attached to both terminals no light. Hmmm
Where do I go next? How do I test the ignition switch or what would be next in line?
The seat belt interlock relay is on the engine side firewall, passenger side
http://home.comcast.net/~vettfixr/page16.htm
Nick
Nick
...I did not have power from my ignition switch to my starter until I did the exact same by-pass fix using vettfixr's method....if your override relay is bad, this "repair" will by-pass it correctly.
This switch is clamped together and over time the clamp (actually little metal fingers) can let loose. If the switch isn't held tightly together it will act up intermittently by not allowing power to flow to the starter solenoid.
You can try reaching down to the switch (on top of the column near your feet) and squeezing the switch to compress it as you turn the key. If it appears loose, or you get an intermittent electrical response as you do this, the switch needs to be replaced or worked on.
Also try moving the ignition rod that goes between the key switch (at the top of the column) and the ignition switch along the top of the column. The ignition switch is held onto the column with some small sheet metal screws that can work loose. If they work loose, it will allow the entire ignition switch to move instead of the internal contacts of the switch which can again result in intermittent continuity problems.
Good luck... GUSTO
Thanks again to all for their suggestions and comments. Great Forum!!
Good Luck
Good luck... GUSTO
Nick
It's much simpler to just splice the green and purple start wires behind the orange mount and leave the relay intact.
