Horney question
Old Oct 3, 2010 | 05:00 PM
omegac1's Avatar
omegac1
Default Horney question
I have a 1968 that I am rebuilding. The assembly manual shows 2 horns mounted near the front of the hood but my car only has 1? Is it supposed to have 1 or 2?
Old Oct 3, 2010 | 05:10 PM
Alan 71's Avatar
Alan 71
Hi O,
I believe 68 cars had 2 horns; a low note on the driver's side, #9000245, and a high note on the passenger's side, #9000246.
Regards,
Alan
Old Oct 3, 2010 | 05:52 PM
omegac1's Avatar
omegac1
ttt
Old Oct 4, 2010 | 06:03 AM
naasaa's Avatar
naasaa
My 68 has two horns.
Lars
Old Oct 5, 2010 | 06:53 AM
omegac1's Avatar
omegac1
ttt
Old Oct 5, 2010 | 06:55 AM
omegac1's Avatar
omegac1
Iteresting thing is that there is not even a hole for a bracket to mount that would hold another horn. Is there a year of C3 that only had one horn on the drivers side near the middle bewtween the two headlight diaphrams?
Old Oct 5, 2010 | 10:35 PM
Darrell's 68's Avatar
Darrell's 68
Mine has two as well and it's an early 68.
Old Oct 6, 2010 | 07:19 PM
72LS1Vette's Avatar
72LS1Vette
72 had only one horn that mounted in that position. Maybe someone replaced the headlight support bracket that bonds to the fiberglass at some point. If you don't have bumps in front of the headlight openings due to corroded rivets that's probably the case.
Rick B.
Old Oct 9, 2010 | 05:08 PM
omegac1's Avatar
omegac1
Maybe thats it becqause the install looks very "stock". There isnt even qanother wire floating around to attach to a second horn.
Old Oct 9, 2010 | 11:11 PM
John 65's Avatar
John 65
Rick B.
68 here, original headlight bar just removerd a few months ago and glued back in. 2 horns.
To Horney question
