ZZ4 HEADERS?
Old Apr 1, 2002 | 11:10 AM
Ken74Conv's Avatar
Ken74Conv
Default ZZ4 HEADERS?
What headers is everyone running on their ZZ4 in a C3.
Old Apr 1, 2002 | 11:26 AM
theandies's Avatar
theandies
Default Re: ZZ4 HEADERS? (Ken74Conv)
I have Headman Headders from Jim Pace Parts. ZZ4's have "D" shaped exhaust ports and Headman makes headders for the ZZ4. I like them.
John
Old Apr 1, 2002 | 04:35 PM
Ken74Conv's Avatar
Ken74Conv
Somebody else must have headers on their ZZ4.
Lets hear you!
Old Apr 1, 2002 | 05:41 PM
C3Vettesrock's Avatar
C3Vettesrock
same, i used pace parts hedman headers with d port
Old Apr 1, 2002 | 08:00 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: ZZ4 HEADERS? (C3Vettesrock)
Hooker Header /Sidepipes :yesnod:
Old Apr 1, 2002 | 08:53 PM
VetteNut72's Avatar
VetteNut72
Hedman block hugger style - The true equal-length type I tried first fit but one tube blocked the clutch shaft that runs from the engine to the frame.
I now am running RPM 6085 centerbolt heads, H.O.T. cam, 1.6 rockers and ProFlo EFI. In the process of getting it running now.
BTW - A friend now has my old ZZ4 heads along with a performer RPM intake and XE268 cam in his previously stock 76 motor. He bought hedman headers also. The car runs like a bat! :D :D
Old Apr 1, 2002 | 10:00 PM
Green76's Avatar
Green76
Ken,
I run Hooker Super Competition 1 3/4" tubes, Ceramic coated headers.
They fit really well no flow restrictions or problems with clearence easy to install and they don't melt any of my plug wires. They are expensive but you get a quality product...
Old Apr 1, 2002 | 11:32 PM
Chris Butchart's Avatar
Chris Butchart
Dynomax Ceramic Coated- Fit great only $219.00 from Jegs :D
Old Apr 2, 2002 | 09:49 AM
Mack's Avatar
Mack
Default Re: ZZ4 HEADERS? (Green76)
Ken,
Me, too...
Old Apr 2, 2002 | 11:08 AM
kgraumann's Avatar
kgraumann
I run Hooker headers on mine also from Summitt Racing. I thought I would save money and buy the none ceramic coated ones, but have soon taken them off and had Airborne Coatings put a ceramic/black coating on it, so much better looking now, and lot cooler in the engine compartment now.
These were expensive, but worth it to me.
Old Apr 5, 2002 | 06:15 PM
RodsbyRad's Avatar
RodsbyRad
Default Re: ZZ4 HEADERS? (Chris Butchart)
I just called Dynomax and they don't make headers for the d-ports, only oval port. :nonod:
Was hoping for those, they are a good price and I have heard good comments on them. Guess I'll have to look for a different brand, probably Hooker as I've had those on several rides and had good luck with them.
Rad..
Old Apr 5, 2002 | 08:10 PM
Chris Butchart
The dynomax headers will fit the ports on the ZZ4 heads regardless of shape. They did on mine and I have no leaks :chevy
Old Apr 5, 2002 | 08:19 PM
72rdstr's Avatar
72rdstr
Default Re: ZZ4 HEADERS? (Mike69)
Mike69,
Hooker assured me that their sidepipe headers wouldn't fit angle plug heads! Doesn't the ZZ4 have angle plugs?
If so, did you have to mod anything?
This was the build up I had planned but was changing my mind due to the info from Hooker.
:confused:
Old Apr 5, 2002 | 08:45 PM
paso's Avatar
paso
Default Re: ZZ4 HEADERS? (72rdstr)
72 rdstr don't believe hooker . I still can't believe they reduce sales by stating that when only one plug is hard to get out.
Old Apr 5, 2002 | 11:38 PM
72rdstr's Avatar
72rdstr
Default Re: ZZ4 HEADERS? (paso)
Paso,
thanks for the info. Looks like I'm back in business with the ZZ430!!
:cool:
Old Apr 6, 2002 | 02:04 PM
1980ZZ4's Avatar
1980ZZ4
Not to knock other header brands, but I've owned several on different applications and have only personally been happy with the Hookers. On the Vette I have the ceramic coated Hooker Super Comps and once again am very happy with them. Expensive, but worth it.
Old Apr 6, 2002 | 03:54 PM
spikezz4's Avatar
spikezz4
Hooker Super Comps ceramic coated. We had them port matched with the cylinder head exhaust ports when the heads were CNC'ed.
Spike
To ZZ4 HEADERS?
Old Apr 6, 2002 | 05:58 PM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
I put Sanderson's on mine, they have a set that is made for the ZZ4 and better yet a set for the 385 Fast burn heads. Bolted right up with no problem and no leaks.
Old Apr 8, 2002 | 01:47 PM
RodsbyRad's Avatar
RodsbyRad
Default Re: ZZ4 HEADERS? (1980ZZ4)
You guys that have the Hooker Super Comps, what part number did you use? I show 2 possible, both have 1 3/4 primaries, one is 28" tubes, the other is 25" tubes. They also have different collector lengths. Which are you guys running:
2108 - 28" tubes, 8" collector length
2134 - 25" tubes, 10" collector length
Here's the application chart at their website:
http://www.holley.com/HiOctn/ProdLin....html#Corvette
I will be getting the thermal coating, but trying to figure which one of these is right for me.
Rad...
Old Apr 8, 2002 | 02:55 PM
Mack's Avatar
Mack
Default Re: ZZ4 HEADERS? (RodsbyRad)
2134-1 is what I used.
