Alternator identification needed ..help!
Old Oct 5, 2010 | 09:50 PM
Iggycat2009's Avatar
Iggycat2009
Default Alternator identification needed ..help!
I have the two alternators and trying to save some $$ by installing #2 which is freshly rebuilt, but appears the amp rating is lower than the one installed and not sure it'll work. The housings and electrical connections are almost identical on both. I'm looking to find out what year each alternator is. Any help would be appreciated.
1) this one is already installed in my 1976 C3;
1105565 78A
6F04 12VNEG
2) This one is rebuilt and ready for installation but not sure it'll work on my 76 C3, the Amp rating is lower;
1100946 55A
3H17 12VNEG
Mike
Old Oct 6, 2010 | 05:07 PM
MelWff's Avatar
MelWff
I dont think you can go by what is stamped from the factory on a rebuilt alternator. The rebuilder may have changed the rating. They both should be bench tested to see what you really have.
Old Oct 6, 2010 | 07:23 PM
Mike Ward's Avatar
Mike Ward
Either of those alternators will work on your car if you don't have a/c. Neither is from a Corvette, the first one was built in 1973, the second in 1976.
Old Oct 7, 2010 | 11:58 AM
jasselmeier's Avatar
jasselmeier
How is the coding deciphered? Is this in Corvette by the Numbers?Thanks - Joe
Old Oct 9, 2010 | 12:16 PM
Iggycat2009
What makes an alternator significant to a Corvette? If these are both GM alternators, what is the difference?
Mike
Old Oct 9, 2010 | 01:33 PM
toddalin's Avatar
toddalin
Mike
1) Part number stamped on the case, and sometimes clocking of the case.
2) Originality = resale and/or collector value.
Old Oct 9, 2010 | 01:38 PM
toddalin's Avatar
toddalin
1105565 78A
6F04 12VNEG
1105565 is the GM part number
78A = 78 amps
6 = 1976
F = 6th month
04 = 4th day of the month
12VNEG = 12 volt negative ground
Old Oct 9, 2010 | 03:48 PM
Mike Ward's Avatar
Mike Ward
Correct on all counts.
To Alternator identification needed ..help!
