Why is the aluminum one there? Does it have to do with the aluminum intake ?
It should be stainless steel and it seals off the exhaust passage that goes across, from the intake.
The steel goes against the bottom of the carb , then the gasket.
edit - Aluminum intake ? I don't think the SS one I'm thinking about is used on the aluminum intake.
If you have the "smiley-face" exhaust crossover intake manifold, you have to use a 2-piece gasket set, although I recommend a 3-piece. All the info for this, including part numbers, sources, and costs, are in my paper titled "Q-Jet Base Gasket Info." Paper is available by e-mailing me a request:
I have the two above gaskets exactly. Except my metal one does not have the two smaller tabs on the side with the small circles. I am not sure if those tabs have a function or not.
This all starts out from me having three carbs.
A 68 corvette carb that came with the car and I was told it was the original but it has a stripped fuel inlet.
A 75 automatic 350 carb from a truck that was on the engine.
A carb bought off ebay that was supposed to be a replica carb.
None of the three have the same base plate.
The 75 carb doesn't seem to work very well and the new carb is much worst.
I called today and asked around, and even though one place said my 68 carb could not be fixed with a heli-coil, another place said they do it all the time and it was no problem.
I guess I am going to get it helicoiled and rebuilt. I figure it should be the closest. Just take the new carb as a lesson learned.
Any of those carbs can be set up to run just fine - there is no issue with manifold/gasket fitment to the carbs provided the correct gasket set is used as outlined in the info I e-mailed you. You can see that the truck carb has been run on a "smiley-face" intake manifold without use of the correct gasket - you can see where it has been ingesting exhaust gas with a huge vacuum leak, so that carb was probably running like crap without the right gasket set.
