Dim Headlights on 82
Old Oct 6, 2010 | 08:25 PM
Scuba Nut's Avatar
Scuba Nut
Default Dim Headlights on 82
The headlights on my 82 are very dim. When I drive after dark i have to use high beam just to get close to normal and high beam isn't all that bright either. Anyone know of a fix for this???
Old Oct 6, 2010 | 11:05 PM
71406's Avatar
71406
Check to make sure your headlights are grounded properly.
Old Oct 7, 2010 | 12:33 AM
MN-Brent's Avatar
MN-Brent
Buy new ones, halogens.
If that doesn't work, try the headlight relay mod to get max voltage to your headlights. Do a search and you will find the very simple wiring diagram to make this set-up work. It will also save your old headlight switch in the dash from overheating and smoking, failing, etc.
Old Oct 7, 2010 | 08:54 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
I agree check the ground but ,the new Halogens make a big difference.Ron
Old Oct 7, 2010 | 11:03 AM
7T1vette's Avatar
7T1vette
The stock '82 lighting should not be "dim". Halogens will be brighter, but that is not a FIX for your problem. The ground wiring for the headlight system is obviously defective. It may be 'present', but the wiring and/or the connections are offering excessive resistance and reducing the voltage available to the lamps. Removal, inspection, and [probably] replacement of the grounding wire(s) is likely the only solution.
P.S. You might also feel around the area of the headlamp switch when you are running the lights. If it feels excessively warm, your switch could have similar problems. Years of use can cause burned/pitted contacts in that switch and result in added resistance, as well.
Old Oct 7, 2010 | 10:22 PM
TJP440's Avatar
TJP440
UHM check the dimmer switch as well. You either have a bad
ground(s), bad headlight switch, or bad dimmer.
To Dim Headlights on 82
