Update on '71 LS6 (pics available)
[Modified by geopar, 7:49 PM 4/1/2002]
[Modified by geopar, 7:52 PM 4/1/2002]
Thanks for posting the update on the 1971 LS-6 convertible and yes, I'd love to see the photos!
I guess the big question that I have concerns the L 17 70 (December 17, 1970) block casting date and the T1028CPX (October 10 [1970]) assembly date... There really isn't any way possible that the engine could be assembled before the block was cast so there is something not quite right here. I gather that you confirmed the numbers on the pad?
Everything you have stated about the car so far sounds appropriate for an LS-6 except for the discrepency mentioned above.
Regards,
[Modified by Rowdy Rat, 1:35 PM 4/1/2002]
j/k...... what do I know?? :rolleyes: MJ
Just to be safe, confirm these numbers yourself and be careful to watch out for a re-stamped engine pad. Also, look for threaded oil boss for external oil system by oil filter. This indicates a 4-bolt main, which it should have.
All other numbers look good according to my reference material.
Good Luck, Mark
Geo
