Brake Rotor drama
Old Oct 7, 2010 | 03:31 PM
richiev88's Avatar
richiev88
Default Brake Rotor drama
The 69 I purchased arrived in NZ in June. All vehicle new to this country have to pass a stringent inspection before they can be registered here.
During the inspection the inspector deemed the front rotors to be outside spec according to his manual. I replace the front rotors.
Since getting the car registered I have driven a couple of 300 mile stints of which the car starts off with a good solid brake pedal, by the end of the journey pedal is hard on the floor!
After reading up about this issue on the forum and measuring the rotor run-out with a dial gage ( had 7 thou on one side, 5 on the other) decided to get the new rotors machined on the car. ( even though I was losing pedal and getting air in the system, I could not feel any pedal pulse)
I drove the car yesterday after having the rotors machined...terrible pedal pulse....whats going on?????
I measured the rotors after the machining less than 2 thou run-out still.
I removed the wheels again and measured ( the out side face of the rotor) still less than 2 thou run out?
Whilst rotating the rotor I noticed the inner brake pad pulsing in and out!
Some how during machining process the rotor has gained a variation in thickness.
As the outer surface has very little run-out only the inner seems to be affected??
Has anyone had this issue before??
Cheers
Old Oct 7, 2010 | 03:34 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Inspect your pads for uneven wear. It will be pretty obvious...
Old Oct 7, 2010 | 03:37 PM
MelWff's Avatar
MelWff
are you sure the wheel bearings are properly adjusted? try cutting the rotors off the car.
Old Oct 7, 2010 | 03:58 PM
richiev88's Avatar
richiev88
The bearings are new, no play, pads are also new hawk items
Old Oct 7, 2010 | 04:35 PM
Mike Ward's Avatar
Mike Ward
If you've got 2 thou runout on each side, but the high spots are in line with each other, that would be 4 thou variation in thickness.
If so, it sounds like the on-car machining was not done correctly.
Old Oct 7, 2010 | 07:23 PM
richiev88's Avatar
richiev88
Yes thats what I have concluded too. Trouble is probably have to pay another operator to correct the issue....
Old Oct 7, 2010 | 11:37 PM
richiev88's Avatar
richiev88
Cheers
Hi,
Looks like I have a resolve, have had the rotors re cut, it was a lathe operator issue, now we are well within spec, aoround 2 thou
Fingers crossed no more spongy brake pedal
To Brake Rotor drama
