Looking for distributor info
Old Oct 10, 2010 | 12:20 PM
ChrisJP85's Avatar
ChrisJP85
Default Looking for distributor info
So I spent my obligatory 45 min trying to use the search function to answer this without luck.
Anyway, I want to unbubba my ignition and I'm looking for generic information on distributor. I have a windowless distributor (which leads me to think it's an old junkyard swap) and I just want to put in the most cost effective stock option. Just not sure what I need to replace. I.e. the whole thing (about $500?) or just the rotor (a lot less)
So, any links or comments?
Old Oct 10, 2010 | 12:33 PM
Solid LT1's Avatar
Solid LT1
Model year of your Vette would be helpful, up to 1974 they had Delco cast iron tach drive distributor, after 75 aluminum HEI units. Late HEI's are cheap early distributors with tach drives can run some $$ in proper working order.
Old Oct 10, 2010 | 12:41 PM
ChrisJP85's Avatar
ChrisJP85
Sorry, I've got a 69 350 qjet. A lot has been readily replaced with non-matching items
Old Oct 10, 2010 | 04:00 PM
...Roger...'s Avatar
...Roger...
Here is what you need.
http://forums.corvetteforum.com/c3-p...tributors.html
Old Oct 10, 2010 | 05:14 PM
ChrisJP85's Avatar
ChrisJP85
That's awfully convenient haha. I'll take one of those.
Old Oct 10, 2010 | 09:24 PM
JimT's Avatar
JimT
Be careful with after market HEI dizzys. They look great and have a decent tach drive gear. The electronics are ok but the advance weight pins are shoddy. Most are pressed in and they will eventually fall out - slinging weights and springs everywhere. Not a good thing. If you purchase one of these, go ahead and take it apart and have the weight pins tig welded in place (from the bottom), then you should be ok.
Good luck.
To Looking for distributor info
