Trouble starting
Old Oct 10, 2010 | 01:07 PM
pwsusi's Avatar
pwsusi
Default Trouble starting
Hi,
I'm having issues getting my '71 started after driving it for some time ('71 LT-1 ...with holly carb). When the car is cold it pretty much starts right up as long as i pump the gas to get enough fuel into the carb. After driving the car for 10-15 min if i shut if off and try to start it it will start right up. However usually I'm running to the store or something...so after driving it will usually sit for 5-10 min before i attempt to start it up again...that's when it's pretty much hit or miss as far as getting to start.
When i turn the key the car will turn over but just not start. It has a brand new battery so i know that's not the problem. A friend told me it's probably a a carb issue...he told me to get a small cup of gas and pour it into the carb when it won't start. I tried that but it didn't work (seems there's plenty of gas in there and have flooded it once or twice while struggling to get her started).
I have 2 71's, so i tried swapping ignition coils between the two cars thinking that may be it, but that didn't help either. Not sure what the next step is. Ideas?
Thanks,
Paul
Old Oct 10, 2010 | 04:08 PM
...Roger...'s Avatar
...Roger...
Your going to have to isolate why it won't fire. Too much fuel or no spark sounds like your 2 choices since you tried the cup of fuel.
Does it have TI ignition ?
edit- are you running with all the shielding on the motor ?
Old Oct 10, 2010 | 04:14 PM
pwsusi's Avatar
pwsusi
Out of the two i suspect no spark because it won't start with or without the cup of fuel. Yes the car has TI, but the amp is not hooked up.
Not sure what you mean about all the shielding on the motor
Old Oct 10, 2010 | 04:24 PM
...Roger...
The chrome shielding around the dist can absorb the spark if you have a bad wire.
I was going to suggest you leave the top cover off and see if that makes a diff.
You could also leave the cover off and carry an extra plug wire and plug to check for spark when it won't start.
Old Oct 11, 2010 | 06:43 PM
LB66383's Avatar
LB66383
It could be that gas is percolating out of the carb and into the manifold while it's sitting. So it's too rich to start. Have you tried holding the accelerator pedal about halfway to the floor while you crank?
Old Oct 11, 2010 | 07:47 PM
pwsusi's Avatar
pwsusi
I tried without the ignition shield and no luck. Also tried pumping the pedal, not pumping the pedal, holding it halfway, etc...no dice. Maybe i need new spark plugs? or maybe a problem with my distributor?
Thanks,
Paul
Old Oct 11, 2010 | 08:08 PM
...Roger...
I would find an old plug wire and plug.
Next time it happens , remove the top cover , unplug a wire from cap , plug in the old plug wire and lay plug on intake manifold,crank the engine and see if the plug fires.
That will tell you which direction to go.
To Trouble starting
