1973 Mirror Map Light
From there you can see the electrical connections and change/clean the bulb.
The only connection that you can not get to is the top power wire pole that hits a spring for the switch.
Try dropping the switch and cleaning it, hopefully that will do the job.
Hope this helps.
Terry
