good elec fan setup?
Old Oct 22, 2010 | 09:12 PM
mj9311's Avatar
mj9311
what do you think of this setup ???
http://www.jegs.com/i/Be+Cool+Radiat...75007/10002/-1
Old Oct 23, 2010 | 03:47 AM
cv67's Avatar
cv67
St. Jude Donor '05
Originally Posted by straub18045
cant beat the price on 'black magic fan' comes with all wiring and relays. think 3300 cfm and not loud.
I almost bought that one for mine how do you like it? 3300 is some kick butt cfm for a single.
I only have a 50 amp alt so everyone and their mother said dont use it.
Went with a 16" single spal which is only 2360 I think...highly modded 350 with underdrive pulleys. So far so good but may look into that one you got thats 1000 more cfm.
Did you use the probe temp switch system or the traditional type?
Old Oct 23, 2010 | 06:11 AM
baxsom's Avatar
baxsom
You can find the entire MKVIII set up on ebay sometimes. I got the fan and relay there for like 120 bucks. It came with wiring as well as the part number for various temp controllers. You have to upgrade your alternator but there are many options for that as well. Overall it cost me 200 bucks for everything.
Old Oct 23, 2010 | 09:16 AM
mikep3's Avatar
mikep3
Default Electlric Fans
I went to electric fan for noise reduction. Had to change the alt. to a 100 amp.
No heat trouble, but did go with aluminum rad. when the original started to leak all over.
Have not run on a hot night with lights on around town, that would be a real test. We get few hot nights in central New York.
Fan Controller, soft start adjustable temp.
http://www.jegs.com/i/Flex-a-lite/400/31165/10002/-1
Fan, 16" 2000 cfm 20 amps
http://www.jegs.com/i/JEGS/555/52110/10002/-1
Fan Mounting Kit
http://www.jegs.com/i/JEGS/555/52120/10002/-1
Old Oct 23, 2010 | 09:18 AM
speedreed8's Avatar
speedreed8
these are what i have, dual spal, basically the same as above, a little less $$
http://www.a1electric.com/Merchant2/..._Code=30102052
http://www.jegs.com/i/JEGS/555/10560/10002/-1
Old Oct 23, 2010 | 09:24 AM
Billysvette's Avatar
Billysvette
That looks like it will work,we only have 25 inches between the radiator and a-arms. anything wider will not work,it will hit a-arms.The flex a lite fan i have is 27 inches,it fits radiator ,but wont fit between a-arms.
Old Oct 23, 2010 | 02:39 PM
mj9311's Avatar
mj9311
im more concerned with the cfm on them... it should be sufficient right
Old Oct 23, 2010 | 03:38 PM
Vetteran'81's Avatar
Vetteran'81
I'm running a Be Cool fan and radiator setup, and they work great. Mine are billet aluminum finish and look fantastic. Be Cool's wiring harnesses and temp sending units make it easy for a gorilla fingered noob like me to work on.
Just my opinion...
Old Oct 23, 2010 | 03:44 PM
mj9311's Avatar
mj9311
cool thats what i like to hear i did also get there harness with it so should go together nice thanks for all the input
Old Oct 23, 2010 | 03:47 PM
Vetteran'81
Good luck with the project. Post some pictures when it's done!
Old Oct 23, 2010 | 04:05 PM
Billysvette
Also,i guarrentee if you use water wetter in your radiator it will stay cool.i used in my other vehicle 3 to 4 bottles of the stuff and it cooled it down 20 degrees cooler,it really works.I have a intercooler ,condenser,oil cooler,in front of my radiator and i just added water wetter and it cooled it down with out any other mods. this vehicle is supercharged too,builds alot more heat in the engine,its a v8 truck,modified ,with stock radiator.it use to over heat when it got 90 and above outside.
Old Oct 23, 2010 | 04:15 PM
Vetteran'81
You can see the radiator and fans in this photo. Not the best angle, but you can get an idea.
Old Oct 23, 2010 | 05:55 PM
  #33
mj9311's Avatar
mj9311
will deff post some pics probably in a week or two... this is where im out now
Old Oct 24, 2010 | 12:31 AM
  #34
mj9311's Avatar
mj9311
so this is the wiring kit i got http://www.jegs.com/i/Be+Cool+Radiat...75117/10002/-1
how would i wire it up so they both have to bypass a switch first?? i want to be able to turn the 2nd fan on and off any ideas??
