Tranny Conversion
Old Oct 14, 2010 | 11:44 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by Gordonm
It does get very tight but mine went in with no fiberglass mods. I also use the stock ebrake system with no mods. I did have to modify the crossmember drasticly though.
Same experience here. I initially cut a hole in the passenger side of the tunnel to allow clearance for the driveshaft U-joint but after lowering the trans some more that turned out to be unnecessary. I also left the e-brake bracket as-is.
Rick B.
Old Oct 15, 2010 | 12:23 PM
KeislerSales's Avatar
KeislerSales
Originally Posted by meinthe73
I think an LT1 style t56 may work as well. New or used.
Difficult and expensive to make work with the pull style clutch. Go LS if you choose the T56 route.
Old Oct 21, 2010 | 08:31 AM
naasaa's Avatar
naasaa
Keisler
How will the T45RS hold up with 383 stroker set up for street performance?
Lars
Old Oct 21, 2010 | 10:15 AM
KeislerSales
Originally Posted by naasaa
Keisler
Lars
The T45 is the last performance transmission developed by Borg-Warner and is essentially a 5 speed version of the T56 6 speed. It is a very reliable and robust transmission offering smooth shift quality and quiet operation.
It will hold your 383 stroker with no issues. Watch this video below and pay attention to what tranny he is running before he launches.
http://www.youtube.com/watch?v=MfGKMUb1GCA
Old Oct 21, 2010 | 12:11 PM
Young69Owner's Avatar
Young69Owner
The only true bolt-in 5 Speed is a T-5 built by SKSpeed. I still have my original driveshaft and 76 mph comes in at 2,000 rpm.
