I wanted to get some advice on what carb I should run on my modified 77 vette that I purchased this year.
I'll be doing some small work in the winter - I just purchased an Edelbrock Performer air-gap RPM intake and I'm looking for a carb change - I want more performance - the car is just a cruiser - but I may want to take it to the drag strip for a few runs each year - I'm not worried about gas mileage - so interested in opinions.
What I have in the car now is:
350 bored over .30 and it has a set of Brodix aluminum heads (170cc intake ports, 69cc combustion chambers, 2.02/1.60 valves, 1.25 valve springs.)
Also it has a Lunati cam – 224/224 duration@ .050, .460/.460 lift. Crane 1.5 ratio aluminum roller rockers. TRW forged pistons. Exhaust -Hooker headers through 40 series Flowmasters no cats.
350 auto trans has a B&M Hole shot 2000 stall converter and 3.73 gears.
What do you recommend?
Thanks-
Reason: added more info
I think something in the 750 CFM range would be good for that set up. I like the holley DP,s because there easy to tune. Regardless what carb You put on. You will want to have someone dial it in for You, or learn to to dial it in Yourself.
I would definitely need one to help tune the carb, I've tried in the past and I would need mechanic to help out, I also want to have my transmission shift points looked at and adjusted due to the carb and intake manifold change.
Any other advice? Many people say that the 750 DB would work, but some say that since I have an auto I would need a larger stall converter. I have 3:73 gears so that should help. The holley tech actually suggested that the 670 street avenger would be a better choice... I wonder if he was just thinking about better mileage vs performance?
A 750 would be a good choice with a couple of things to consider-
Your off the stop performance will be down a bit, because of the lower speed airflow thru the carb at low RPM. That will be offset by the performance above 3000 RPM.
The other thing is that if you use a mechanical secondary carb, there's likely to be a bog or sag in the midrange transition that will be a bear to get rid of. I'd suggest going with a vacuum secondary carb. Those have a better "signal" to the secondaries and open them as the engine demands. Mechanical is controlled by your foot.
Tuning is not as big a thing as you might think- it tales patience and some tools, but it can be done. In general, the Holley and Demon carbs are fairly close right out of the box, just need some tweaks to get to right on. That's where a wideband O2 meter gets handy.
I would recommend you look at the Holley ultra series carburetors, we have had very good results with them. the #76750bk 750 cfm may be a good choice for your engine.
I have almost the same setup as you (slightly bigger cam).
Holley tech support said that 670 street avenger will fit my setup perfectly. I also asked few tuners/engine builders and they said the same.
S.
scyzork23- Thanks for the info - the Holley Tech also told me a 670 street avenger is the right choice, but so many people and mechanics are telling me that I should go with a 750 DB..... I guess I can play it safe with a 670, but I just don't want to regret not getting a 750 if that could help out with performance.
Holley 670 will be good until you hit solid 400hp.
If you think that you might be there than use 750.
S.
Originally Posted by Vette Cruz-in
scyzork23- Thanks for the info - the Holley Tech also told me a 670 street avenger is the right choice, but so many people and mechanics are telling me that I should go with a 750 DB..... I guess I can play it safe with a 670, but I just don't want to regret not getting a 750 is that could help out with performance.
