Intake manifold gaskets?
Old Apr 2, 2002 | 11:20 AM
MikeC's Avatar
MikeC
Default Intake manifold gaskets?
I have a stock intake manifold with exhaust crossover. I heard there are gaskets with a blocking plate to block off the crossover. I think Fel pro makes one. Anybody got the part #
Old Apr 2, 2002 | 01:24 PM
MikeC's Avatar
MikeC
Default Re: Intake manifold gaskets? (MikeC)
TTT for the lunch crew
Old Apr 2, 2002 | 02:13 PM
Ben Taylor's Avatar
Ben Taylor
I think it's MS90314-2, But I had to get this off AutoZone.com, since my work only lets me go to certain sites.
By the way, most parts stores should have this in stock, and they will usually open it for you and let you see the parts.
If you can't find one, I have two of those plates that I could send you, since my car doesn't use them.
[Modified by Ben Taylor, 11:15 AM 4/2/2002]
Old Apr 2, 2002 | 02:20 PM
John's Shark's Avatar
John's Shark
Default Re: Intake manifold gaskets? (Ben Taylor)
MS90314-2 is for 69 - 82 chevy sb's. You can see a good picture of it on Summit's web site. It shows what appears to be 2 separate exhaust cross over block off plates that are optional pieces that come with the gaskets. However, they appear to have small holes in the middle of them as well. This is consistent with the Felpro's I just used on my performer intake except they were an integral part of the gasket. Hope this helps
Old Apr 2, 2002 | 02:42 PM
MikeC's Avatar
MikeC
Default Re: Intake manifold gaskets? (John's Shark)
Thanks guys
To Intake manifold gaskets?
