Name that wire
Old Oct 17, 2010 | 08:59 AM
omegac1's Avatar
omegac1
Default Name that wire
I am rebuilding a new to me 1968. I have the gauge cluster removed to repair some electrical issues and I have several connectors that I can not ID where they go. They are all part of the stock wiring harness.
Heavy brown wire/connector that is hot when the ignition is on. Left side of cluster opening. It is very short and looks like it would attach to the ignition switch but it doesnt.
Connector with pink and green wires.
Heavy black wire most likely ground that was cut off.
Old Oct 17, 2010 | 09:56 AM
flaco1801's Avatar
flaco1801
my guess is the brown had a capacitor plugged into it...for noise suppresion of the radio... the pink wire connector looks like a flasher maybe, for the 4 way...
Old Oct 17, 2010 | 10:51 AM
jnb5101's Avatar
jnb5101
pink and green should be the back up light wires. the wiring harness that's in my 72 project (unknown year) has two pink and greens with different connectors, but electrically are the same.
Old Oct 17, 2010 | 11:55 AM
omegac1's Avatar
omegac1
ttt
Old Oct 17, 2010 | 12:04 PM
wiseman79's Avatar
wiseman79
FROM MEMORY, the 2 wire connector that is at a 90 degree agle looks like the TCC wire that on my 71 connected just above the throttle pedal.
Old Oct 17, 2010 | 12:09 PM
...Roger...'s Avatar
...Roger...
The heavy black should be a ground. You should have a black female that attaches to a spade on the speedo and another black female that attaches to the tach and another black but with a round connector that I believe ( not 100%) screws to the frame that the round black wiper **** switch is mounted in. Then a brown/white strip wire attaches to the switch. Some 68 guys should be able to help with that.
Old Oct 17, 2010 | 03:55 PM
omegac1's Avatar
omegac1
"TCC Wire" ?
Ground wire comment....interesteing becasue I found earlier that my wiper were not working because the wiper **** that sits between the two manual vaccum lines was not grounded.
Old Oct 17, 2010 | 04:02 PM
...Roger...
Originally Posted by omegac1
"TCC Wire" ?
See if you have both blacks going to the tach and speedo, if you do that black might be the one that grounds the wiper **** switch.
To Name that wire
