headlight door loose
Old Oct 17, 2010 | 09:02 AM
larry hinterman's Avatar
larry hinterman
Default headlight door loose
There is a star bracket on the left side of the passenger headlight door and it doesn't move by hand anyway. A fitting with a elm screw holds the headlight door to the bracket and it fits loosely.
Should the fitting be tight?
What does the star bracket do?
the driver side headlight door is not loose and the fitting seams to be tight.
Old Oct 17, 2010 | 10:53 AM
Alan 71's Avatar
Alan 71
Hi LH,
The part with the three bolts is the bearing assembly. It provides the pivot point for the headlight door. It needs to be adjusted to get a good door to surround fit.
The round stop(you can just see it) with the allen screw in it is the stop that slides onto the door's pivot rod. It helps position the door side to side in the surround.
Good Luck.
Regards,
Alan
Old Oct 17, 2010 | 10:56 AM
jnb5101's Avatar
jnb5101
alan-i hate you! no car should be that clean!!!!
Old Oct 17, 2010 | 11:00 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by jnb5101
alan- no car should be that clean!!!!
Got to agree on that one...
Here is the adjustment pic from the aim. It may help you some too!
Willcox
Old Oct 17, 2010 | 11:25 AM
Alan 71's Avatar
Alan 71
Being that clean has its down side too.
Regards,
Alan
To headlight door loose
