electrical, gen/alt conversion
Old Oct 17, 2010 | 01:31 PM
firstvett69's Avatar
firstvett69
Default electrical, gen/alt conversion
1969 350/350. The generator was swapped over to an alternator years ago, I was told since then the amp gauge does not work. Can the gauge work with the alt or no, The gauge is always just off to the + side when I undo the gauge wire nothing happens. With multimeter The red and black wire both read around 13.8 the black wire is hooked up to the small brown wire, I assume is the gauge wire is this the wright way for this to be hooked up? I have had no problems with charging and or lights every thing works except the amp meter. THANKS TO ALL YOU ELECTRICAL GUYS. Not one of my best fields
Old Oct 17, 2010 | 02:19 PM
7T1vette's Avatar
7T1vette
The ammeter doesn't care whether you have a generator or an alternator. It merely senses the current flowing in the main power line and displays it on the gauge scale. It does not have that current flowing through the meter; it only senses that current. You have a connection problem elsewhere...or, when the alternator swap was made, the original wiring was altered.
Old Oct 17, 2010 | 03:12 PM
toddalin's Avatar
toddalin
If you have a '69 that had a "factory" generator, it was a one off as all C3s had alternators.
I'm thinking that maybe you mean that they previously changed the stock alternator out for a 1-wire alternator.
Old Oct 17, 2010 | 06:32 PM
firstvett69
Your correct not generator, thinking about my vw just changed it to an alternator, sorry. The 69 alternator is chrome not sure if its the original and it was chromed or not. But the double wire plug in red and black wire, does the black wire connect to the small brown wire I believe goes to the gauge, amp meter. All these wires have been cut at one time, trying to figure out why, and why the gauge does not work.Thanks.
To electrical, gen/alt conversion
