Any install issues 4L80E into a 69 C3??
Old Jul 6, 2016 | 11:23 PM
97C5's Avatar
97C5
One last follow up. More info here from usshift and just so happens I have one of these unused in box with wiring harness if interested (I'm using holley setup)
http://www.usshift.com/downloads/GMmanual.pdf
Old Jul 7, 2016 | 12:47 AM
gkull's Avatar
gkull
Originally Posted by Street Shaker
Thinking of installing a Hughes 4L80E over-drive tranny into my 69 C3. Wondering if any of you guys are running this set up and have you had any issues installing/fitting the tranny?
If it was me I would install a new 6-8-10 speed auto. The 8 and 10 speeds come in the new ZL1 Camaros
Old Jul 7, 2016 | 07:09 AM
L88Plus's Avatar
L88Plus
Slip yokes are from single cab trucks, bolt-on from anything with a 2-piece driveshaft - extended and crewcabs.
You don't have to use the later model trannies with one cooling line in back, there is an internal oiling mod that gets the same thing done, then you can use the transmission with both cooler lines in front like the old stuff. Sure makes it a lot easier to connect and disconnect those lines.
I've been scavenging 4L80E's from part-outs for years, only have 8 or 9 of them now...
Old Sep 5, 2016 | 01:13 PM
Stu's81's Avatar
Stu's81
Can I use a slip yoke with the bolt on shaft? Or will this weaken it?
Old Nov 22, 2020 | 09:05 PM
TreDawg's Avatar
TreDawg
Default How much Fluid?
Sorry to bump this old thread, but how much fluid is required for the 4L80E with a shallow pan? Thanks!
