Any install issues 4L80E into a 69 C3??
Old Oct 17, 2010 | 09:05 PM
Street Shaker's Avatar
Street Shaker
Default Any install issues 4L80E into a 69 C3??
Thinking of installing a Hughes 4L80E over-drive tranny into my 69 C3. Wondering if any of you guys are running this set up and have you had any issues installing/fitting the tranny?
If i decide to swap trannys I will be selling my full set up GForce T56 6spd tranny custom built to handle 1300hp, with bell housing, McLeod off-set shifter to fit the stock counsel, custom cross member, and the driveshaft. its a complete bolt in set up.
Old Oct 18, 2010 | 07:46 AM
markdtn's Avatar
markdtn
What will you use to control it? It needs a computer to operate.
Old Oct 18, 2010 | 09:55 AM
jimvette999's Avatar
jimvette999
I had to deform the trans tunnel about a 1/2" to clear the drive shaft yoke. Other than that, the cooler lines are best converted to -AN to make them accessible. Try and buy a later model of the 4L80E with one cooler line routed to the center hub vs. both at the dipstick tube location. It was a GM correction to facilitate better lubrication to that area of the trans. to prevent failure under severe duty. TCI among others sell the TCU. Holley makes an EFI engine management controller that also controls the transmission. An ECU/TCU plus a bunch of other goodies all in one... grab yer wallet.
Old Oct 18, 2010 | 10:42 AM
Vogie's Avatar
Vogie
Take a look at Gearstar. They build some smaller, lighter units for high power application and have a good warranty.
Old Oct 18, 2010 | 02:43 PM
Tumarr's Avatar
Tumarr
If you need a trans to survive above 700 hp, dont even think about going with something 4l60 based. stick to the 4l80. This is the guy to go to for 4l80's. he is the most trusted by the really fast guys who want overdrive.
http://www.jakesperformance.com/4L80E.html
Old Oct 18, 2010 | 05:06 PM
ajrothm's Avatar
ajrothm
I would like to see how the hell you guys are getting 4l80s in a vette....any pics of these installs? Cutting up the floor tunnels?
A 4l80e is like 6-8" longer and thicker then a t400....
I am thinking about a Mike Kertz 200r4....about $3k though.
Also FYI, see the recent thread here about Jakesperformance.
Old Oct 18, 2010 | 11:26 PM
7T1vette's Avatar
7T1vette
Why a 4L80E (electronic) instead of a 700R4? They're basically the same mechanical unit, but you don't need a major electrical harness, a computer and all the peripheral sensor inputs to make it work properly.
Old Oct 19, 2010 | 12:59 AM
my72vette454's Avatar
my72vette454
I converted from a 4 speed to a 4l80e several years ago and the only thing I had to do was drill a hole through the drivers side floor board for the main electrical plug to clear. I used that spot to bring the wiring inside anyway so no big deal. I didnt have any other clearance problems except I couldnt use the stock dipstick and bought a locar cable dipstick, but its a tight fit. mine was the earlier model with the front cooler lines. I used a Powertrain Control Solutions controller for it. I used the stock auto shifter and added 2 micro switches to the side of it. one switches from auto to manual and the other is my mini paddle shifter, bump it one way it upshifts and the other way it downshifts, kinda fun actually. After blowing up two 4 speeds and wanting an overdrive trans I decided to try a 4l80e and so far its held up behind my twin turbo 468 pushing around 800 ft lbs of torque.
Old Oct 19, 2010 | 01:56 AM
gkull's Avatar
gkull
I had a 850 hp 700R4 and Monty went to the 4L80E with his 1200 hp TT dart 427 raised cam small block.
The 200's can't take on big TQ at a certain point it becomes the case strength and the limits of the internal parts.
Then as power gets to high enough level the need for multi gears goes away and that is why the old two speed glide is what is used in up to 2000+ hp drag cars
Old Oct 19, 2010 | 08:37 AM
jimvette999
While tight, they do fit. No cutting was required in my case. This is the first Gen., I later swapped it out for the second Gen. with relocated cooler line to center hub and sleaker pan. I used a Lokar dipstick tube. IMO, you can't go wrong with a 4L80E, bullet-proof. A 700R4/4L60E....not so much. That's like comparing a TH350 to a TH400.
Old Oct 19, 2010 | 10:07 PM
Street Shaker
Great info guys!!! Thats what I needed to know, thank you!
Thanks for the input, I called Jake this morning good people, I need a tranny to hold up behind my 568CID 870hp pump gas with 2 stages of nitrous roughly about 1300hp but I like to go over kill just to be save.
I talked to Carol at Russler Transmission 4L80E that he modifies is currently surviving behind cars making around 2500hp with no problems at all, but the price is pretty stiff $6400.00 for the tranny alone.
Ryan at Hughes Transmission make one rated 1000hp for $3757.00 and a stronger one rated to 1800hp $4385.00 reverse pattern manual shift with trans brake and all. Lock up converter another $1200 and option manual or automatic shift extra $550. He sad his tranny is currently behind a 1200whp turbo car in the low 8's holding out pretty good, and thats with using the over drive on the 1/4 top end with a lock up converter.
Still getting info and shopping around, but after hearing from you guys that it will fit I will be installing one in the next couple months for sure, any more info would be greatly appreciated.
-Paja
Old Dec 7, 2010 | 11:07 PM
Street Shaker
Well I ended up having CK performance build one for me, should be arriving sometime this week. My T56 6-speed is for sale is a complete bolt in kit, check the parts for sale section
Old Dec 8, 2010 | 12:43 AM
Vette5.5's Avatar
Vette5.5
Actually the 700R4/4L60 is more a decendant of the TH350, with the 4L80 being more a decendant of the stronger TH400. 700R4's can be made plenty strong for most street application's, but think the OP is talking some major hp/abuse here.
Old Jul 18, 2011 | 10:07 PM
Street Shaker
Finally installing my 4L80E transmission in my 69 Vette. It's tight, but it fits without any tunnel modification and already have the crossmember made. I used CSR carbon fiber bellhousing shield made for TH 400 SFI approved , fits real nice with just a slight modification by trimming the ends off to clear the bellhousing.
What shifter are you guys using to fit the stock console for manual valve body standard pattern? Thanks !
-Paja
Old Jun 13, 2016 | 05:41 PM
NewbVetteGuy's Avatar
NewbVetteGuy
First post a double post?!? Really?!? *Sigh* "NewbVetteGuy" name fits, I guess.
Adam
NewbVetteGuy
Tell me more about this mini paddle shifter setup; even better if you have photos. I'm doing a 4L65E swap on a 79 and found a EZ-TCU on CL and I REALLY want to do paddle or paddle-like shifters but paying $350 for the TCI paddle shifter setup (which doesn't work with the stock steering wheel) seems expensive; I'm good at electronics and I'm SUPER interested in how you did this.
Adam
Old Jul 5, 2016 | 06:55 PM
Stu's81's Avatar
Stu's81
Which transmission yoke are you using?, I picked up a 4l80e and it has a bolt on yoke.
To Any install issues 4L80E into a 69 C3??
Old Jul 6, 2016 | 12:45 AM
NewbVetteGuy
You've got the holy grail solution here for electronic GM transmissions; PLEASE for the love of all that's good, share how you did this.
I've scoured the internets far and wide, I've sent far more email questions to TCI than I'd like to admit and I've posted to the TCI online forums with NO reply.
HOW THE HECK, do you wire in your own switches to switch to manual mode and then do bump or paddle shifting?!?
You have no idea how much I want to do this; it's an obsession and you're the only one who I've found who's claimed to do it so far.
TCI wants to sell me their $750 dollar wireless paddle shifter, but I'd prefer to just reuse the wires already running to my horn to mount a switch or fabricate a paddle shifter to the OEM steering wheel and make $50-$100 paddle shifters for my EZ-TCU controlled 4L60e. (Yes, I know we have different trans controlllers and I'll still need to figure out how to do it with the EZ-TCU unless I wire direct into the trans harness.)
Adam
Old Jul 6, 2016 | 11:07 PM
97C5's Avatar
97C5
With holley trans controller, this thread will get you started. If you don't have holley efi, an expensive proposition.
http://forums.holley.com/showthread....mmanding-Shift
Old Jul 6, 2016 | 11:09 PM
97C5's Avatar
97C5
Stu, my 4l80 has normal slip in yoke. Think yours is from 4wd or something maybe?
