pulling motor advice
Old Oct 18, 2010 | 04:21 PM
Bowerss2's Avatar
Bowerss2
Default pulling motor advice
I am pulling the motor on my 80 this weekend to turn it into a 383. I have a good grasp on what i am doing but i have a few last questions.
is it easier to pull the engine and tranny out as one unit?
and more importantly how much time should i set aside for this?
i was looking at the radiator today and was wondering if i can pull the rad and condenser out by removing the radiator support. This looks like it may save some time. Is this true?
cheers all
Steve
Old Oct 18, 2010 | 04:37 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
The factory installed it that way. Makes sense to take it out that way. I can't speak for an '80 SB with A/C (and auto?), but it should work the same. Use a good quality engine leveler and consider coming in from the side with a cherry picker, removing one of the front wheels. Car should be on jack stands...I put the rear wheels on ramps and had the front on jack stands set to the lowest position...gave the car a slight incline. You may want to consider propping up the front clip when you pull the radiator core support package...probably not necessary though.
The amount of time it will take depends on the help you have and the amount of beer consumed.
Old Oct 18, 2010 | 04:47 PM
Gordonm's Avatar
Gordonm
Are you going to have the transmission rebuilt? If the trans is staying in the car with no mods then leave it in. I have pulled many an automatic motor out without pulling the trans. In fact it is very easy to pull just the motor out. If you just pull the motor out you don't even have to pull the radiator. Remove the lower pulleys and it will come out no probelm. The time it takes depends on your skill and tool level. I can have mine out in about 2 hours by myself. I swear mine has zippers on it by now.
If you are planning on doing trans work then pull it out as a unit.
Old Oct 18, 2010 | 08:50 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
These guys pretty much covered it. I don't think I'd pull the radiator support because it does tie the front end fiberglass to the frame. An engine leveler is a must if pulling it with the transmission. Don't forget the ground strap on the pass. side near the engine mount. The hoist arm needs to be fully extended.
Old Oct 20, 2010 | 09:30 AM
straub18045's Avatar
straub18045
ive pulled my motor every winter it should have velco mounts. floor jack under trans, dont touch rad support., remove hood and your good to go. i have a small 2 car garage so i lower vehicle as low as possible on jacks stands but high enough that engine hiost slips under, and cringe as you motor dangles over you fender.
Old Oct 20, 2010 | 09:54 AM
BryanB75's Avatar
BryanB75
over you fender.
I'm getting mine ready to pull out too and that very thought has been going my head every time I look at it
Old Oct 20, 2010 | 12:13 PM
TopGunn's Avatar
TopGunn
Don't you have to remove the waterpump, pwr steering pump, alternator etc also?
Old Oct 20, 2010 | 09:25 PM
mj9311's Avatar
mj9311
water pump can stay i pulled the alt and ps pump cause it was easier took the carb off too took me about 6 hours from time i pulled the hood till it was out and on the stand.. disassembling the motor is a whole different beast
Old Oct 21, 2010 | 07:03 AM
TopGunn's Avatar
TopGunn
Interesting, never thought there was enough room. I may try it that way next time.
Old Oct 21, 2010 | 02:26 PM
Bowerss2's Avatar
Bowerss2
so you say it should take about six hours?
Old Oct 21, 2010 | 06:34 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Separate trans from engine, unhook alternator wires, A/C compressor unbolted from mount and set aside (tie to to the fender with wire), same for P/S pump, remove the pulleys, unhook all hoses, unhook and pull the distributor, take out the two long motor mount bolts, unhook the ground cable, unhook and remove the starter, remove the three torque converter bolts, unhook the exhaust pipes from the manifolds, remove the six bell housing bolts, unbolt the accelerator cable bracket (and cruise control bracket), jack up the front end, remove a front tire (I use the right side), put a jack under the trans (use a board or something between the jack and pan), hook up the engine hoist as previously recommended, double check that everything is loose, then GENTLY raise the engine while slightly moving it forward to release the transmission, then lift it up and over the fender. Leave the hood, radiator, and shroud in place. Cake.
Old Oct 21, 2010 | 10:12 PM
mj9311's Avatar
mj9311
yea about 6-8 hours i think. it was the first time pulling a motor out of a car ( i pulled 1 out of a bmw and a honda but i cut the frone end off and pulled straight out so not sure if they count ) i pulled the hood, rad. and support, carb and ps pump and i left the trans in the car though i did pull that later. it wasnt so bad just a PITA from the side cause the nose is so long and i did break the shroud trying to force it out . i am planning however to reinstall the motor and trans as one
Old Oct 22, 2010 | 06:19 AM
aworks's Avatar
aworks
Good advise. I pulled and reinstalled the motor in my 69 a back in June without touching the shroud.
Old Oct 22, 2010 | 08:12 AM
MN80Vette's Avatar
MN80Vette
I didn't see anybody mention this, but every engine hoist I've seen is too short to lift your engine from the front. I put my '80 on jack stands, removed the front left wheel, and came in from the side. The problem then will be that the hoist will not lift straight up. It will lift to the outside, and you will need to keep moving the hoist to stay straight above the engine. The same is true when lowering everything back in.
Old Oct 22, 2010 | 01:43 PM
CaseyJones's Avatar
CaseyJones
Mine hoist is from Harbor Freight and has a 2 ton capacity. The lift arm is adjustable and I had very little trouble. Having someone "drive" the hoist is very helpful. I see your point about being able to lift straight up. The long arm made it a little less of a problem.
Old Oct 23, 2010 | 12:56 AM
MN80Vette's Avatar
MN80Vette
Are you saying that Harbor Freight has an engine hoist that will reach from in front C3 bumpers to the center of the engine? If so, I'm pressed. I'll have to look into that if I pull trigger on engine upgrades.
Old Oct 25, 2010 | 10:16 AM
straub18045
my hoist is from harbor freight, but i pick from driver side by fender.
To pulling motor advice
Old Oct 25, 2010 | 11:48 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
That is what I had to do with my 71. I have some good shots of putting the ZZ4 in the car, but the removal of the previous engine went about the same. Check out this link.
http://www.boomnit.com/Cars/Project71/Engineswap.html
Old Oct 25, 2010 | 12:03 PM
beachcomber's Avatar
beachcomber
Great write up of the swap and nice pics. Did you go with the ZZ4 350 or the 383? How was your first ride experience once you did the swap? Was it night and day? Meet or exceed your expectations? Anything you'd do differently?
Old Oct 25, 2010 | 12:49 PM
Sigforty's Avatar
Sigforty
I did the ZZ4 350. At the time I did the swap it was because the engine came with a warranty and I was still in school. I was very pleased with the swap. I never got a chance to reach the full pontential of the engine though due to Hurricane Katrina. I would definitely do it again if I had the chance. My current plans though are to put a 454 in the car as I am restoring it.
