1976 Tranny Slipping
Old Oct 19, 2010 | 09:45 AM
GunMan57's Avatar
GunMan57
Cruising
Default 1976 Tranny Slipping
Greetings,
My 1976 TH350 seems to be slipping. When I first start driving it is okay; at 70 mph the tachometer reads around 3500 rpm. After about 20 minutes or so, to maintain the 70 mph, my tachometer goes up to 4000 - 4200 rpm. Is this a tachometer problem or transmission problem? Also, is it the torque converter? I believe I have 3.08:1 in the differential and am running the stock 350 CI. I have replaced the transmission filter and fluid and added transmission "fix" fluid to it; the problem persists. Any suggestions will be appreciated...thanks!
Old Oct 19, 2010 | 11:09 AM
MelWff's Avatar
MelWff
do you hear a whining sound? does the trani fluid smell burnt? If no it's probably the tach.
Old Oct 21, 2010 | 09:29 AM
GunMan57's Avatar
GunMan57
Cruising
No, the transmission fluid I removed didn't have a burnt odor nor was discolored. There isn't any whining noise either. As far as the tachometer goes, is there a "simple" fix I can try?
Old Oct 21, 2010 | 02:16 PM
7T1vette's Avatar
7T1vette
Well, normally, slipping could be caused by low oil level. But, since yours works fine until it gets really hot, I suspect your oil level in the tranny might be too high. If you get too much fluid in an auto tranny, it starts "churning" and foaming up. The 'foamed' oil does not have the same frictional characteristics and can start slipping in gear. Recheck your oil level with the engine and tranny fully warmed up. Do that after you take it for a short drive, sometime.
Old Oct 25, 2010 | 10:20 AM
GunMan57's Avatar
GunMan57
Cruising
Thanks, I'll re-check the levels after I drive it.
Old Nov 15, 2010 | 06:31 PM
ImBlackMomba's Avatar
ImBlackMomba
Ive got a whining sound... and unfortunately a faint burnt smell. I know its bad.
Is it worth draining and replacing filter? Or should I take a trip right to the tranny shop?
Old Nov 15, 2010 | 10:04 PM
JasonC3's Avatar
JasonC3
I would certainly try a filter kit...it is cheap and has been known to prolong the life...
Old Nov 16, 2010 | 06:00 AM
7T1vette's Avatar
7T1vette
Pull the tranny dipstick and smell the oil. If it smells 'burnt' [instead of having a 'sweet' smell], the clutch plates in one of the clutches are worn out and slipping when activated. Time for a rebuild or tranny swap.
Old Nov 17, 2010 | 09:34 PM
Vette5.5's Avatar
Vette5.5
Sound's like it's time for a re-build, as the whining is usually a bad pump bearing and the burnt smell a bad clutch pack. If you can pull the tranny yourself, and take it to a shop for a standard bench re-build, probably save yourself some pretty good money. Risk is, if the shop messes up and doesn't road test afterward's, could turn into a real headache.
To 1976 Tranny Slipping
