Detonation
Old Oct 20, 2010 | 04:14 AM
pj_corvette's Avatar
pj_corvette
Default Detonation
My car is detonating under certain conditions, and I'm trying to figure out the reason.
I have it set up for 36 degrees total advance, all in by 3000 rpm. Vacuum canister adds 16 degrees, for 52 total. I only have access to 91 octane fuel here, so that does not help.
So, the car has a 2004R transmission. It will detonate sometimes when in overdrive. Like the other day I was going up an on-ramp, and it shifted into overdrive, and started detonating.
I read the sticky on timing. It says to check for detonation by putting the transmission in high gear and then accelerating from low rpm. But I have an auto tranny, and this the transmission would just simply downshift.
So, how can I tell if I have too much timing from the vacuum can or just too much timing from the mechanical advance?
Old Oct 20, 2010 | 04:21 AM
cudabob's Avatar
cudabob
Cruising
My guess, 36 mechanical is too much. When floor it, vacuum goes down, and your left with all mechanical. Just reduce the mechanical by 2 to 4 degrees and see if problem goes away.
Old Oct 20, 2010 | 04:23 AM
cudabob's Avatar
cudabob
Cruising
Also, sometimes your not getting the full 91 Octane. Try maybe a little octane boost.
Old Oct 20, 2010 | 06:45 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
Sorry to bust in here but I also set my timing to 36 and the car hesitates every once in a while. Usually when just cruising not under WOT.
Is it easy to tell if it's detonation or could it also be a carb issue?
I guess I could retard mine as well and see if it gets better?
Old Oct 20, 2010 | 07:10 AM
gingerbreadman1977's Avatar
gingerbreadman1977
almost any performance orientated engine if lagging in overdrive and floored will detonate....you might not hear it but doesnt mean its not happening.
Its a little unclear if you said you were in a healthy part of the powerband or if you were just cruising. if you combine a on-ramp (especially up-ramp) with overdrive and you dont drop a gear to something suitable then its going to get angry with you.
so i might be jumping to conclusions but is your trans shifting down as it should?
Old Oct 20, 2010 | 07:52 AM
L88Plus's Avatar
L88Plus
I think your 52* of timing is the culprit - you're firing the plug when the piston is only about halfway up the cylinder. Aim for 36 or so TOTAL.
Old Oct 20, 2010 | 08:06 AM
BLOCKMAN's Avatar
BLOCKMAN
Are you using port vacume or manifold vacume????
Old Oct 20, 2010 | 08:12 AM
bashcraft's Avatar
bashcraft
If it only happens in situations like you described, just adjust your kick down so it down shifts sooner.
Old Oct 20, 2010 | 08:28 AM
RIO68's Avatar
RIO68
Never heard mine doing it but it cost me 2 broke pistons and now a new set to replace them all. 700r4 3:70 rear gears--thought it was downshifting OK but going back to the drawing board.
If you hear it best fix it!
Old Oct 20, 2010 | 11:34 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I bet you have too much vacuum advance. Vacuum advance compliments mechanical. Try running with Vacuum advance disconnected. I bet 10* vacuum advance is all she can handle with today's gas.
To Detonation
